BBS Garage: All things BBS
This is a sticky topic.
  • Jim Lepage
    • Jul 2008
    • 1138
    #1021
    E30S54 - Scale Suspension / Unix Performance Coilovers - 17x8 and 17x9 BBS E50
    • 5ickride
      • 2922
      #1022
      Wow! Those look tasty
      • Vivek
        attention whore/retard/bitch
        • 6167
        #1023
        Hey BBS entusiasts, I have a question. I'm reassembling my rc090's and I'm having a hard time getting the splined bolts into the holes. Do you guys have any tips? They're not easy to put in and I don't wanna risk forcing it in the wrong way and stripping the holes. Should I try some WD40 or other penetrating oil, or a lubricant, to get them to slide in? The bolts are fairly new and look brand new with no corrosion or anything. All I've seen online are people hammering them in or threading a nut on the back and forcing them though, and that seems like it could potentially damage the splines on the barrels.
        TL;DR, need to get my splined bolts in asap, help?
        1992 Mauritiusblau Vert
        2011 Alpinweiss 335is coupe
        2002 540i/6 Black/Black
        2003 GSX-R 750 (RIP)
        • dannyyisntt
          • 3141
          #1024
          Originally posted by Jim Lepage
          Wow, those are gonna be sweet! I like how you guys are mounting the center caps too
          • Eric
            • 5141
            #1025
            Vivek- rubber mallet & tap them down.
            • Hunterg
              • Jul 2013
              • 78
              #1026
              There's the finished product of e38 style 5 with polished lips painted grimmspeed goldClick image for larger version
              • formula driver
                • 2263
                #1027
                I doubt you will get them pressed all the way in.
                Just give them a tap with a dead blow, as mentioned. Enough to get the splines started, and than let the nut pull them all the way through.
                • rasjgo1
                  • Aug 2011
                  • 332
                  #1028
                  BBS STYLE 5 everlasting QUESTION
                  Originally posted by rasjgo1
                  http://forums.bimmerforums.com/forum...3#post26575553
                  Any one done this yet??
                  Or does anyone know how it done or even the waffle part # needed to attempt this
                  whats good family has anyone find out a way to make the rs waffle fit to a style five wheel yet
                  • rasjgo1
                    • Aug 2011
                    • 332
                    #1029
                    • Poorboyz
                      • May 2012
                      • 2117
                      #1030
                      Kind of what I did but I just used a rubber mallet to get splines started then put nut on back and finished pulling splined bolt through.
                      Sent from my Galaxy Nexus using Tapatalk
                      Rebuilding since 07/06/2016
                      Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
                      Poorboyz Feedback Thread
                      • formula driver
                        • 2263
                        #1031
                        Thats exactly what I just described. lol
                        • dvnchrstphr
                          • Aug 2012
                          • 121
                          #1032
                          Would anyone know if 30-hole OZ/MSW lips would work as replacement lips for BBS RS003's?
                          Thanks in advance
                          Documentation of my 1991 BMW 318iS
                          • DTFE30
                            • Feb 2011
                            • 471
                            #1033
                            Does anybody have experience running 75 mm studs with BBS RS001 15x7 et25? Will the caps clear the studs with or without spacer ect..
                            • kreasims
                              • Jan 2009
                              • 149
                              #1034
                              Thanks in advance
                              Need some machining as the center of the 003 is slightly larger than the MSW. The bolt holes also need to be enlarged. Doable though.
                              • rzerob
                                • Jun 2013
                                • 2315
                                #1035
                                Does anyone know what these are? And what their value is? Sorry I don't have a better camera than the one on my phone.
