Hidden valve stem hitting tierod end...
  • Bey
    • Jul 2008
    • 479
    I'm having clearance issues with my hidden valve stem. It clears the brakes but hits the tierod end. I was thinking of flipping the tierod end upside down but that might mess up the steering geometry... or will it? Anyone know any good sites that sell flush mount valve stem kits? I would try running spacers but it might end up hitting the brake calipers instead.
    Any help or suggestions would be greatly appreciated.
    wheel specs: BBS RM012 ET33 15x8
    pics of the headache..
    RIP
  • Jbpka06
    • Feb 2006
    • 551
    wow i have never seen those, what did you do with the hole on the lip.
    sorry i can't help with your clearance problem, but flipping the tie rod is probably not the best idea.
    • GotCone?
      • Jan 2008
      • 589
      pick up some flush mount valve stems.
      DETAILS: http://www.mr-gasket.com/ProductDeta...&minselection=
      BUY: http://store.summitracing.com/partde...5&autoview=sku
      Build : Das Drehmoment Ungeheuer
      • Bey
        • Jul 2008
        • 479
        Should I go with Mr Gasket or Gorilla flush mount valves?
        RIP
        • brandon11130
          • Jan 2008
          • 635
          why not? people in the 4x4 community have been doing it for a long time. What difference does it really make? afterall the angle increases anyway on an extremely lowered car and you dont see people installing "bent" tie rods to correct it. As long as you do not have an extreme angle and you align the car properly after i see no problem.
          • Rocla
            • 922
            Originally posted by brandon11130
            . What difference does it really make? afterall the angle increases anyway on an extremely lowered car.
            A big difference.
            And the flipping prcedure would require big modifications to strut or replace the tierod end with uniball joint, the fittitngs on tierod ends are conical.
            Current:
            BMW 320i 2d 2.0 m20 -88
            BMW 325i Cabriolet 2.5 m50 -88
            BMW 316i touring 1.6 m40 -90
            BMW 320i 4d 2,2 m54 -01
