BBS Wheels: are these RS'??
  • Nicademus
    • 2912
    Are these BBS RS wheels? 6.5Jx15H2 34ET pattern center bore is 64 5x114.3 bolt
    Well, posterity, you will never know what it cost us to preserve your freedom. I only hope that you will make a good use of it. If you do not, I shall repent in heaven that I ever took half the pains to preserve it.
    ~ John Adams ~
  • Danny
    • 14216
    Damn truck tires.
    Edit: May be reps.
    Don't RS' have 30 bolts?
    • atomic
      • Jun 2007
      • 5691
      They should say underneath the center caps what model of RS's they are like mine below. Look at the model number chart listed in the BBS garage thread you started.
      I have 15x7 BBS RS's and under the cap they say RS001, along with other information regarding the wheel.
      • kronus
        • Apr 2008
        • 13032
        They have 30 bolts..
        However, pretty much everything is off-spec for e30's. Lug pattern, bore, offset.
        cars beep boop
        • Danny
          • 14216
          Oh, I must have mis-counted.
          I got 32.
          • Nicademus
            • 2912
            Couldn't I get them redrilled?
            ~ John Adams ~
            • Danny
              • 14216
              Well it depends how cheap they are.
              But yes.
              • kronus
                • Apr 2008
                • 13032
                The e30 center bore is 57.1mm, it's 64.5 on those wheels. Even if you get centering rings, there will be way too little room on the hub for 4x100 pattern holes, and most wheel shops will likely refuse to do it to prevent you from suing them when your wheels fall off.
                Also, you'll need spacers, and even then, they'll be 6.5" wide, which is pretty weak unless you go get Kodiak lips to bump that up to at least 7.5".
                Summary: you'll need to get rings, re-drill, and get spacers to even have a chance of sketchily mounting these up.
                Sorry, keep looking. Don't you have RM's already?
                cars beep boop
                • Nicademus
                  • 2912
                  Thanks for all the great info Kronus! :)
                  Yeah I do have RM's but I figure I'll buy these and maybe try to turn a profit?
                  ~ John Adams ~
                  • kronus
                    • Apr 2008
                    • 13032
                    If you are really set on them, you could get something like these adapters:
                    You will most likely need to get them custom made to account for the bore difference properly.
                    cars beep boop
                    • Nicademus
                      • 2912
                      Ummm........I bought them :D
                      ~ John Adams ~
                      • Danny
                        • 14216
                        Oh lawd.
                        • Nicademus
                          • 2912
                          Originally posted by Danny
                          Oh lawd.
                          I'm addicted........now I have BBS RM's and RS' :D
                          I'll move into the BBS Garage now......END/
                          ~ John Adams ~
                          • einstein57
                            • Jun 2007
                            • 10780
                            A wheel repair place that will fill and drill will also fill and re bore the wheels as well. Ask me how i know.
                            www.gecoils.com
