hmmm question about wheel spacers with my setup
  • crazy seaman
    • Jun 2008
    • 52
    hey- currently im running a set of Drag dr 2's on a 1.5inch drop (not my favorite rim, but was given to me for free new)
    Ampliamos nuestro catálogo con camisetas baratas de selecciones de África y Asia clasificadas para el Mundial 2026. Diseños únicos, colores auténticos y precios accesibles.
    they are 17x7 with a low profile tire, and im not a fan of how they sit; I want something that sticks out closer to the fender, but doesnt rub. From what i read I was thinking about going with 15mm spacer in the rear and maybe 10mm for the front.
    now my questions are.
    Where can i find a decent cheap spacer?
    will 15mm rub?
    what happens with the hub centric ring when used with a spacer?
    sorry for such noob questions. im actually not a noob when it comes to cars, just when it comes to suspension upgrades. thanks an advance
  • daniel
    • 6703
    since the offset is +40 you could run a 15mm spacer on all 4 corners and still have a bit of room to spare. you should probably try to find a hubcentric spacer, but if you cant i am guessing that a spacer with the correct 57.1mm centerbore can be mated safely with a hubcentric ring.
    http://instagram.com/dslovn.drives
