Rim question
  • bpui
    • Nov 2008
    • 10
    Rim question
    Hi guys .. im new here. I wanna ask a question about rims for e30.. i found a set of 16inch pcd100 8jj offset25 . Just wondering if i can fit it perfectly to the car .. or i have still need spacer for the rims?
  • Mystikal
    Wheel Fitment Expert
    • 9602
    They should clear the front struts by a mm or 2. Once you mount tires though, there's a chance it will touch.
    I'd try it out, and if it contacts then 3mm spacers up front should be enough (re-use stock bolts). Nothing needed in the back.
    • bpui
      • Nov 2008
      • 10
      thanks alot mystikal .... what size of tyre should i be using it on the rim?
      16x8 ET25 will look deep dish on the car ..right? btw the rim that im looking at is volk racing CV-pro
      • Mystikal
        • 9602
        You have a lot of choices for tires, it's pretty much how you want them to look/perform. Anything up to 225/45/16 (with a good fender roll) is game.
        Dish depends on the rim design, don't count on it being there for sure.
        • bpui
          • Nov 2008
          • 10
          thx alot for the info .. i decided to go for ac schnitzer 16x7.5 ET25 ..
          • Mystikal
            • 9602
            Good choice. 225/45 won't even need a fender roll for those.
