Style 5 bolt removal tool
    Anyone know what tool is needed to remove the bolts from style 5's / BBS RC090?
    Thanks in advance.
    '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
    '87 535i - Vacuum brake conversion [SOLD]
    '93 525iT - 5-speed swap - 320k and counting
    '09 328xi - 6-speed
    not 100% on style 5's, but all the BBS multi piece wheels ive taken apart used a regular 8mm 12 point socket.
    -Dan
    -Dan
      Thanks a bunch, I have to go to Sears to return a Christmas gift so hopefully I can pick one up from Craftsman.
      '09 328xi - 6-speed
        Thanks in advance.
        I assume you are talking about the 2 piece wheels from late E39's etc. (they are all 5 lug). They have a smooth end at the bolt head & a slight indention on the head (on face of the wheel) - no socket will fit the bolt head - the bolt is held firm by splines on the top 1/4" that bite into the barrel. The nuts are on the back side of the wheel & are 10mm 12 point. After the nuts are removed, you will need a dead blow hammer to remove the bolts. Be very careful that you don't mess-up the bolt threads when hammering them out.
        [I
          Yes, those are exactly the wheels I'm talking about. Thank you very much for the clarification on the nut size and the info on how to remove them. I was wondering how they worked exactly with the smooth bolt head.
          '09 328xi - 6-speed
