hi i just got basketweaves 15x7 with a 22 mm offset what would be a good tire size to get... someone else said that this offset was not right for an e30 any thoughts on that will i need spacers ?????
what size tires
Originally posted by MachineMasterGthanks for the fast reply im thinking of going with the wider tire that should be better for handiling rite
Going with the 225's will most likely give you a higher limit, but depending on whether you are lowered or not, you may need to roll your fenders if the offset is et22. I'm running 225's on 15x7's with slightly rolled fenders tucking the rear about a 1/2" and the front tires about even with the fenders with no rubbing whatsoever.'91 318is
