DZ1 sizing
    DZ1 sizing
    Well my ronals are gone, and now with summer approaching i've decided on picking up a set of DZ exclusive DZ1's,
    This is the plan,
    9x16 et25 rears
    7.5x16 et20 fronts
    wrapped in toyo T1R rubber
    225/40 rears
    215/40 fronts
    The question is, will this work without rolling fenders/spacers/modification?
    suspension btw is KW 60/40 drop with koni SA's
    and yes, i searched... then searched some more, and no actually sizing/offset was confirmed
    Tim
    weird, im pretty sure the rear wheels are supposed to have less offset than the fronts in a staggered setup.
    the front setup is fine.
    the rear concerns me a little bit if you got your offsets right. you will probably need spacers, and because of that you will probably need to roll your fenders. 225's are somewhat skinny on a 16x9 so you will have some stretch, which will help clear the fender.
    http://instagram.com/dslovn.drives
