Cb on e30 is 57.1 as is the cb on a Ronal Ls no?
ronal ls with spacers?
Mine are but they have a large inner chamfer at the base so very little engages with the hub. With a 5mm spacer it no longer will engage with the hubcentric portion of the hub and a 5mm spacer is too thin to be internally and externally hubcentic itself.Last edited by LJ851; 04-26-2013, 10:17 AM.Comment
I just wanted to point out that the spacer you posted would not give your wheel hubcentric-ness even though it was posted as hubcentric, it just happens to have a 57.1mm bore. At 5mm it does not matter which spacer you choose with ronal LS, your wheel will not know the difference.Comment
