Wheels spacer information
  • analogjesus
    • Jan 2009
    • 101
    So the front wheels on my car are rubbing once in a while, still drivable but I would like to get the problem fixed. I had to buy hubcentric rings to go inside the wheel, to make the wheel fit. The rings are sloped so that they do not immediately contact the hub, and I am worried if I get spacers that the rings will no longer contact the hub. Have any of you guys ever had a similar problem? I have borbet type c on my car right now, 16". I was thinking of a 3mm spacer because there is space between the wheel and strut tower but not alot.
  • ethree
    • Aug 2007
    • 1215
    Hubcentric spacers? That way you don't need the rings? 3mm is not very much.
    • analogjesus
      • Jan 2009
      • 101
      I wasn't aware they made those, thanks
