17x8 BBS RS question
  • tdokmo
    • 13
    I am trying to fit a set of 17X8 BBS RS's on a '89 325ic, with a 40mm offset. What size spacer would this require with a 215/40/17 tire size?
  • E30SPDFRK
    • 5714
    How would you like them to sit? A 20mm all around would look nice and fit well with those tires, but you could go a bit bigger if you wanted them to sit more flush with the fender.
    Byron
    Leichtbau
    • lov-e30
      • 16548
      I say 10inch in the front and 20inch in the rear to give it that aggressive stance.
      @IRON-E30 aka Edwin:D
      • E30SPDFRK
        • 5714
        now that's some poke :p
        Byron
        Leichtbau
        • lov-e30
          • 16548
          not too bad I personally like that look.
          • daniel
            • 6703
            you said inch.
            http://instagram.com/dslovn.drives
            • Motorsports
              • Feb 2007
              • 2882
              Post pics when your done. I want to see how they'll look.
              • lov-e30
                • 16548
                Originally posted by daniel
                you said inch.
                Oh shiait! I meant 20mm and 10mm................:oops:
                • E30SPDFRK
                  • 5714
                  I don't think he can go any smaller than a 15 in the front due to strut clearance.
                  Byron
                  Leichtbau
                  • atomic
                    • Jun 2007
                    • 5691
                    What is the bolt pattern on the 17x8 et40 BBS RS wheels?
                    I was not aware they came in a 4x100mm bolt pattern, or at least it does not appear they do by looking at the model list of BBS RS's...
                    • tdokmo
                      • 13
                      I am having them custom assembled, as BBS never made a wheel with these specs. I currently have a 2 sets of 15mm spacers that I would like to use front and rear.
                      • lov-e30
                        • 16548
                        Really? I had some ricer wheels with 43-45 offset and only needed the 10mm spacer. You maybe right thou 'cause from I can remember I had a little bit of rubbing issues with no fender rolling.
                        • E30SPDFRK
                          • 5714
                          Really? I had some ricer wheels with 43-45 offset and only needed the 10mm spacer. You maybe right thou 'cause from I can remember I had a little bit of rubbing issues.
                          His are 8" wide though.
                          $5 says your ricer wheels were skinnier :p
                          Byron
                          Leichtbau
