Need help with fitment!!!
  • ThatOneImportKid
    • May 2020
    • 12
    I want to put corvette salad shooters. Looking at a set but they have 255/50/r16 tires. Would that fit on my 325i?
  • jbontke
    • Mar 2019
    • 449
    Those tires are taller and much wider. https://tiresize.com/calculator/ I think you would be beating the fender to get them to fit and not rub in a turn. A smaller tire would work. Also, I think the corvette wheels stick out more than stock. You would be rolling the fenders or adding flares as well.
    • Yuri
      • Aug 2017
      • 92
      I’m in the same boat with saw blades. My wheels are staggered with 17x8.5 +56 in the front and 17x9.5 + 56 in the back. I lined them up and the size adapters I need to run are making me think like this was a bad idea. The tires I’m using will be stretched ...these just came with the wheels I bought. Sent from my iPhone using Tapatalk
      • Yuri
        • Aug 2017
        • 92
        Just an update, I fit these wheels on with ginormous wheel adapters. Well I should say I fit the rears so far. The fronts hit the coilovers so still having some issues. Will end up doing a front 5 lug swap with an angle kit. But with a +12 offset I fit 275/40/17s on the rear of the e30. Sent from my iPhone using Tapatalk
        • Yuri
          • Aug 2017
          • 92
          Just an update, I fit these wheels on with ginormous wheel adapters. Well I should say I fit the rears so far. The fronts hit the coilovers so still having some issues. Will end up doing a front 5 lug swap with an angle kit. But with a +12 offset I fit 275/40/17s on the rear of the e30. I used custom built 1.75 inch 2 piece hub/wheel centric adapters to get the +12 offset on these wheels. Yes I know, terrible idea, but at least they fit perfectly. Adapters are torqued to spec with lock-tight. Also, really neat design, it’s near impossible for the lugs to get loose because they cannot back out due to being sandwiched in by the 2 piece adapter. Still, my wheel bears are going to die so fast... Sent from my iPhone using Tapatalk
          • Yuri
            • Aug 2017
            • 92
            The front would have fit but I put 245/45/17s on a 8.5in wide wheel. This means the tire poked out of the rim a bit and ended up rubbing into the suspension... wasn’t willing to size down the tire to something stretched with a wide body. So now I’m doing a 5 lug swap in the front with an angle kit. Sent from my iPhone using Tapatalk
