5mm spacers, longer bolts required?
  • Mystikal
    Wheel Fitment Expert
    • 9602
    My new wheels are coming and due to the spoke design, they may rub on the caliper despite being ET27. 5mm spacers would fit the bill perfectly, but do I actually need longer bolts to go with them? I have no idea, is 5mm enough to warrant a safety issue with stock bolts? Lastly, would a 5mm spacer (obviously non-hubcentric) cause any sort of issues under extreme load? I'm assuming the ring of the hub would still stick out slightly, but I'm not sure.
    Thanks guys.
  • M-technik-3
    • 18946
    On my race wheels I have longer studs as I too have 5mm spacers.
    • bimmerphile
      • 3495
      the real question is do you want to lose 1/2cm worth of threaded contact between your wheel and hub.
      i wouldn't.
      • Mystikal
        • 9602
        Screw it, I'm doing it once and doing it right. RRT stud kit and 5mm (maybe even 8mm) H&R spacers.
        Thanks anyways. :P
        Edit: Good timing Kris. I was searching on Bfc reading up on what the E36 M3 guys were racing on, seems the RRT kit and H&R spacers are the way to go for hard use.
        • M-technik-3
          • 18946
          Stud kits are nice if you have the proper wheel nuts that are shaped for that particular wheel.
          • UNHCLL
            • 8790
            make sure the studs will clear the caps for your new wheels. otherwise you'll lose the ability to run the wheel covers.
            Below the radar...
            • Mystikal
              • 9602
              Good point.
              I'm also noticing another problem. The wheels (and the stock baskets, and my winter wheels) all have a beveled mounting surface. Apparently H&R doesn't recommend using 5mm spacers with this style. Odd, they don't have a disclaimer on the 8mm model and that also doesn't have a hubcentric lip.
              Help.
              • Mystikal
                • 9602
                Since my 17" wheels and 14" winter alloys have a beveled mounting surface, can hubcentric rings be installed? I'm assuming this is the application of them.
