C101 Pin out for 1993 Touring
  • DEV0 E30
    • Oct 2004
    • 8903
    C101 For Tourings
    These will definitely differ depending on what your car is and options. For example, a 325i touring *should* likely line up with what is known for 325i cars.
    If you located ETMs or other information, feel free to share them for this thread.
    I was able to dig into a few threads and find out and line things up.
    Since my touring is a 318i - while it has AC, it does not have a check panel or some other options.
    I looked at the wires one by one, then matched that to an older thread that listed 1990+ 325i, basically mine was the same but my c101 has more blanks because it has less options.
    Some of these things I like the idea of, so they may get added in later.
    These are body side only color/colours for mine, as my m40 engine harness is long gone now.
    1993 318i Touring
    1. BLUE = Charge - Cluster ?
    2.
    3.
    4. BROWN / VIOLET = coolant temp - signal
    5. BLACK / BROWN = oil pres - signal
    6. GREEN / YELLOW = oxy heat +12v
    7. GREEN = ignition coil - gn - +12v
    8. YELLOW / WHITE = fuel rate (econo)- signal
    9. BLACK = tach signal - signal
    10.
    11. WHITE / BLUE = inspection reset - signal
    12.
    13. VIOLET / RED = fuel relay - +12v
    14. BLUE / YELLOW = speed - signal (from instruments to ECU from cluster C2 Pin 10 bu/yl)
    15. BLACK / GREEN = unloader - signal
    16. WHITE / BLACK = srs - not used
    17.
    18. BLACK / YELLOW = starter - +12v
    19. .
    20. RED / YELLOW = ABS power - +12v​
