New touring owner with worn out suspension and have a quick question. Looking at realoem springs for the front of touring are same as standard e30 but rears are touring specific. I do see that H&R does make a set of springs for touring. What is the general consensus for springs? What are you running? Thanks
Touring suspension question
i went down same path about a month ago — had US H&R sport springs (blue) but my rear was sagging and rubbing.
1. make sure your springs are properly rated for a touring, not sedan/coupe, as the touring trunk needs a higher rated spring to hold the weight.
2. make sure your springs are properly rated for a 4-cyl/6-cyl depending on your motor, same idea.
H&R european site lists this info for E30 Touring:
"SPORT PERFORMANCE SPRINGS 29684-1: year: 87>95 | 2WD | Lowering VA: 30 | Lowering HA: 30 | Comments:6-Zyl"
Actual springs I received were Red colored and marked with:
Front: 29684 VA & Rear: H&R 29684 HA
I know here in the US H&R's red colored springs are "Race" and blue's are "Sport" however from what I gathered, eurospec has a different system.
My car feels great now — zero rub, and zero sag in the rear, even when fully loaded.
Use the part number or the number on the springs to search for them.
Good luck.'89 E30 Touring, '85 911 3.2 Coupe, '89 GB500, '96 XR400
still running the black Bilstein B4's the car had when purchased - had to cut the front bump stops to allow for full travel. was very bouncy at first until i did that but feels fine now.
i like the ride height a lot — for me i prefer more a more tuned oem look than a stanced or slammed look.
i actually raised my rear even a few more mm's with thicker spring pads from E36 since i use my touring often with a lot of weight in the trunk — i like having the utility of a wagon.
i would be curious on going Bilstein B6's some day . . .'89 E30 Touring, '85 911 3.2 Coupe, '89 GB500, '96 XR400
I can tell you that tourings are slightly heavier in the rear. if you are going for stock springs, a vert setup may be the way to go. if you're going coil overs. like BC, I can tell you from experience that the rear must be 8k or 10k barrel springs. i tried BC's stock e30 spring setup which was 6k coil springs in the rear, and they overloaded almost instantly.
Speaking from experience, you for sure need heavier duty rear springs for a touring, and/or possibly longer springs.
I originally went with the stock Ground Control setup for sedans, the rear had WAY too much travel, and I had hardly any adjustable range left on the rear height adjusters. With 5.5 inch long, 475lb/in rear springs, I had to have the collar all the way to the top, and a 12mm spring pad just to keep the rears from tucking. 1 passenger in the back would cause my wheels to scrape the wheel liners.
Ended up getting 6.5 inch long, 550lb/in springs to keep the rear in check.
Even if a touring doesn't weigh more than a sedan, it's weight distribution is completely different with respect to the rear axle. Way more of the weight in a touring is all the way in the back of the car, several feet past the rear axle. This creates a much larger moment for the springs to counteract. A good portion of the rear weight in a sedan and/or coupe, is directly above the axle.
H&R + billy's will always work, I had them on mine before switching to coilovers, add some drophats for a great daily setup.FEEDBACK:
http://www.r3vlimited.com/board/showthread.php?t=316212
BMWCCA #398608
IG @yagayo38
"The Best E30's were built with two camshafts four cylinders and sixteen valves!".
Originally posted by restart View PostTx.
Which bilsteins did you use? With a slight drop.
Bilstein B8’s
Sent from my iPhone using TapatalkFEEDBACK:
BMWCCA #398608
IG @yagayo38
Originally posted by restart View PostPs, what did you do with your old ones....for sale?
Sold them a while back. I have these for sale.... perfect for daily driver
BMWCCA #398608
IG @yagayo38
