e30 touring self leveling suspension delete?
  • rikaro
    • Nov 2012
    • 123
    Does anyone know how one can delete their touring self leveling suspension system? Planning to install coilovers so may as well get rid of it.
    Not much info i can find online.
  • E30SPDFRK
    • 5703
    I haven't dealt with e30 SLS, but for the e24/32/34's (which are likely exactly the same), you remove the entire system in the rear (accumulators, level sensor, "T"s, hardlines, shocks, etc.), then get a 6" female-female brake hose and loop the 2 hardlines coming from the engine bay. The rear springs are usually different between the SLS/non-SLS cars, so you'll probably need to replace them at the same time.
    Byron
    Leichtbau
    • rikaro
      • Nov 2012
      • 123
      Is there a temporary way to plug it just incase i want to run it in the long run?
      • E30SPDFRK
        • 5703
        You could loop the limes and leave all the rest of the stuff in there, but it’s just taking up space and will probably drip all over the ground
        Byron
        Leichtbau
