Do E30 Touring’s retain classic E30 handling?
  • mach schnell
    • Apr 2008
    • 1059
    With better springs and shocks, what do you think?
    Would you say they handle about as well as a regular E30?
    Still fun and sporty?
    Or is it a more boat-like experience?
    Considering trading from a sedan to a Touring. Don’t want to lose the fun handling in the canyons though.
  • lukeADE335i
    • Apr 2013
    • 1384
    I haven't driven one, but I can't see why they wouldn't handle well - the extra weight in the rear would probably bring the touring closer to 50/50 where as most e30s are closer to 54F/46R.
    There's a video floating around the web of an e30 touring with an M20 stroker on sticky rubber beating a stock 335i on the track.
    My e30: OEM+ with M30B35
    • Motheye99
      • May 2018
      • 853
      https://youtu.be/iBkObmAPvs0
      Fantastic video
      91' 318is 90' 325is
      Originally posted by Sonny
      Buy the E30s, they ain't gonna last long
      E30 can make you, E30 can break you
      "He who controls the Nova's, controls the Boomers"
        • 34839
        The weight is hardly any different, and it's all in the back. Yeah, I don't know why it wouldn't be the same. But I've never driven one either.
        • mach schnell
          • Apr 2008
          • 1059
          You guys make a lot of sense. Sounds logical.
          • Shangsta
            • 1485
            I have owned a vert, coupe, and a touring. They all feel the same in general minus the weight and where they are placed changing the feel just slightly
            :shock:
            • leegf
              • Dec 2010
              • 1168
              Originally posted by Motheye99
              Came in here to post this
              E46t
              • tcheb
                • Jul 2008
                • 619
                I have owned several E30s 3 325es, one M3 and one 325ix touring. All drastically different cars but all of them were super fun to drive. The touring suffered from a high center of gravity due to stock ix suspension. Nothing that can't be fixed.
                • earthwormjim
                  • Jul 2014
                  • 434
                  Touring creaks and flexes a little more, but it's really not noticeably worse than a sedan from a driver feel perspective. The back seats are also noisy if you're really driving fast on a track, since they aren't mounted to anything rigid.
                  I haven't noticed the weight, it still feels like a relatively light car. Similarly optioned out sedans of the same year are maybe 100lbs lighter, and that's a big maybe. I can't really tell I'm driving a touring until I look in my rear view mirror.
                  • rikaro
                    • Nov 2012
                    • 123
                    I've owned a 325is, and 2 318is (all coupes) and now a 325i touring. The thing that was the most noticeable to me is the increased chassis flex on the touring but it's not all that bad. Despite that, the car handles amazingly well and it's still practical. Currently my car has KW v3, ST sway bars, and all the subframe reinforced plus bushings replaced. I've also added LSD. It's incredible how well and fun the car is now (I own a modified miata too) and i drive the e30 more. I might be a bit biased here but it's tough to find a car that you can feel so much on the front axle and still be able to make a trip to Ikea with new furniture.
                    I would like to add a bit more chassis bracing eventually but that's something to be done down the road.
                    I've also driven a s52 swapped e30 touring and got pulled over but luckily got away with a warning because it's a family station wagon ??. Regardless, I like myself a subtle car but it does get a bit of attention from here and there.
                    Fun fact: The 325i touring is actually 50/50 weight distributed at 1180kg.
                    • rikaro
                      • Nov 2012
                      • 123
                      One more!
                      • mach schnell
                        • Apr 2008
                        • 1059
                        Interesting. What kind of bracing could you add to a Touring?
                        And, do all 325i Touring’s have ABS?
                        • roguetoaster
                          Biggus Tippus
                          • 7826
                          Not much without sacrificing utility, and unless your suspension will be very stiff you probably won't notice the chassis flex too much, although it is there when pushed.
                          Probably not, haven't had an M20B25, but my 88 324td didn't, my 89 320 didn't, and 1/2 90ish 318i tourings did. I suspect it remained optional in ROW markets, whereas it was standard in the US from 87 on.
                          • earthwormjim
                            • Jul 2014
                            • 434
                            For what its worth, my '89 build year 325i touring had every option, including ABS, except for cruise control.
                            • mach schnell
                              • Apr 2008
                              • 1059
                              I’m looking at an ‘88 that has ABS, it turns out, which I think is a nice to have option, even if it is an older version.
                              The chassis flex thing is interesting. Some people seem to think it’s non-existent even on super-stiff suspension. Others mention noodles.
                              I guess I just don’t want it be an annoyingly creaky thing.
