5-Series Showoff Thread
This is a sticky topic.
    Originally posted by nickflic3 View Post
    Temporary wheels off a e90 535 till the schnitzers are done.
    an e90 535i? RARE! lol
      Gaahh my bad; 335!!
      Cammed B25 Swap Daily Driver
      Updated 10/1
        Gaahh my bad; 335!!
        LOL! Had to poke some fun! I actually don't mind those wheels...
          finally detailed her and snapped some good photos. didnt finish my 17" style 5s in time for this though:
          ive done a couple things so far to the exterior:
          early side mirrors
          smoked euros with bixenon retrofit
          smoked turns with amber bulb
          all red tails
          front and rear plate filler
          shadowline
          needs: front end lowered, style 5 wheels.
            Lookin good.
            I've got a perfect set of 16" Style 5's if you're interested.
              After installing new suspension last night, e38 staggered m-pars.
                Originally posted by TrentW View Post
                Lookin good.
                thanks! already have some 17" ones though.
                  M-pars are one of the best OEM wheels for our cars. Ride height looks good also.
                  Cheers,
                  Jim
                    for those that dont know, the m-pars were factory equipped on some e34s.
                    All M5 sedans and Tourings built after May of 1994 were upgraded to staggered M Parallel Spoke wheels measuring 8x18-inches in the front and 9x18-inches in the rear. These carry 245/40ZR18 tires on all four wheels. Note: Though nearly identical in style to the 18-inch M Parallel Spoke wheels later used on the E38 7 Series, the E34 M5 wheels have a different matte silver finish and a unique offset.
                      http://youtu.be/AgeVMVoScaE
                      had some fun after replacing my cooling system
                        Heres a crappy "teaser" shot...e39 525i on NNR coilovers. She sits quite low lol. Sitting on Hartge Nova 7's in 19x8.5/9.5...front offset is at et7 right now but soon to be et-5, tire size 215/35/19, rear tires get mounted on tuesday, 225/35/19, et22 (stock wheel offset) and after I get the wheels on ill see if theres more room to push em out...id like to be at et15 in the rear.
                          Needs moar low.
                            early side mirrors
                            all red tails
                            shadowline
                            Did you modify the sedan rear plate filler or use the sticker type?
                            Photo?
                              Originally posted by MeanM50 View Post
                              Needs moar low.
                              Hahaha funny thing is, I want to chop a coil off the rear springs since they are maxed out and its too much rake. Might even pull the front helpers out too. Tuck 19s static like a boss!
                                Photo?
                                plasti-dip. its perfect for this application. cheaper and less time consuming than modifying or buying and cutting vinyl. just remove the plate, tape the edges, spray. peel off whenever you want.
