My engine rebuild B10 BT
  • Alpina
    • Oct 2004
    • 838
    Hello all..
    Last winter a did a rebuild on my B10 BT..
    New camshaft ((oem M30B35 used on BT)) new bearings .025 and a turned crank,,
    ARP.. MLS 0.70" or 1.78 mm thick.. turboes got also new bearings an overhaul,,
    all gasket etc etc ,, new oem Sachs clutch, as i am putting over 550nm to the wheels before rebuild,, and the car feels much stronger now
    SACHS Performance Clutch Kit for Alpina B10 E34 3.5 Biturbo ✔ SACHS - the technology partner of BMW and Porsche Motorsport as also BMW GT3 clutch supplier.
    oem B10 BT piston.. 7.2 CR
    Car is nr, 346 and the engine-code is B7/5
    M70 starter ( more powerful)
    All rocker-arms are X-rayed.. and market 8) i didnt change them as they were in superb condition
    reworked intake........ port...... Beautyfully done oem
    Exhaustport are oem BMW size
    OEM twin turbo,, the first M30 twinturbo ..afaik
    Sveinbjörn Hrafnsson
    E30 CABRIO V12 M70B50 ///
    ALPINA B10 BITURBO 346 @ 507
    E34 550 V12 JML
    Finnish wisdom : If you want to Win,, hire a Finn
    http://alpina.123.is/pictures/
  • Alpina
    • Oct 2004
    • 838
    Intake pipe,,
    With intercooler pipes
    Engine covered with oem heatshields
    intercooler.......
    The flywheel......... the biggest/thickest EVER you have seen on a BMW engine
    3" thick........ and leviathan weight,, the engine is VERY smooth
    This is just the flywheel ,, no clutch
    Heat and oilpressure.........oem
    Engine with Getrag 290.. the most rock solid gearbox ever made from GETRAG,, this gearbox is used in the USA fleet of heavy pick-up trucks,, that are made to hawl texas to the east-cost..
    as you can see the gearbox is huge compared to G260/280
    here is a V8 gearbox..6 speed G420 compared to G290.. the bellhousing of a V8 BMW engine is a lot bigger vs IL 6,, but anyway
    The flange is biggest i have ever seen........ 150mm x 42 is the GUIBO,, the same as on 850 CSI
    Ready to install
    This is the auxiliary waterpump for turboes ,, so when you shut down the engine after driving,, and the oiltemp is 70°c+ the pumps go on... pretty smart system IMO
    E34 550 V12 JML
    • Keith M
      • 2338
      I hate Icelanders and there 50000 hp cars. :D
      That is a really nice build. Picture of the car this motor is going in?
      • 1craze30
        • 1224
        The g290 is a direct swap from what trucks? I'm curious. Nice build man. You sure can make a turd shine like a diamond.
        • slammin.e28
          שמע ישראל
          • 12054
          YESSSSSSSS!
          Loving this Alpina content! YES YES YES!
          • Alpina
            • Oct 2004
            • 838
            The G290 share just the invols,, with USA pickup trucks,, the bellhousing is the same as G260 and G280
            http://coloradok5.com/forums/showthread.php?t=143587
            imarksweb.net is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, imarksweb.net has it all. We hope you find what you are searching for!
            http://67-72chevytrucks.com/vboard/s...d.php?t=456441
            thanks for comment
            E34 550 V12 JML
            • 1989325ii
              • Oct 2007
              • 164
              wow
              • Jean
                • 18228
                Very cool! Whas the pn on that oil cap?
                • mikewbd
                  • May 2012
                  • 39
                  Oh my this is amazing
                  • Alpina
                    • Oct 2004
                    • 838
                    I dont follow you ??
                    E34 550 V12 JML
                    • CarsSuck
                      • Oct 2005
                      • 968
                      I think Jean is asking about the lid for the oil filter canister with the fittings for pressure and temp. sensors. PN = part number
                      --Will
                      • Alpina
                        • Oct 2004
                        • 838
                        The ALPINA partnr is ...... 1142011 for the oilfilter cover
                        E34 550 V12 JML
                        • sbeckman7
                          • 94
                          Wow very nice engine!!! I would love to make one myself someday. So on the exhaust there is an X-pipe and no cats? Could you describe or show the rest of the exhaust system as well? Thanks!
                          • Alpina
                            • Oct 2004
                            • 838
                            Well,,,,,,
                            The X-pipe is oem,,, and made of stainless steel.. were the oxygen sensor plugs in the pipe is around 95mm+ or 3.7" in diameter ..
                            the stainless steel exhaust i made ((had a guy who welded for me)) is 2 x 63mm or 2.5"
                            The muffler is made/designed by myself and is a blend of oem/eisenmann..... replica
                            The car is a ,,,little to loud IMO,, ok on full throttle but when driving slowly below 3000 rpm the car is ,,brummming .........
                            can be annoing,,, so maby i will put a middle section this winter
                            E34 550 V12 JML
