I have a 95 touring and it currently has the 17 in 5 spokes that are heavy and I don't like them. I got the lighter weight 16 inches from the 740il and they have 235/60s on them which don't fit. What tire size will fit? 215s?
E34 touring with 16in 7 series wheels - what tires?
225/60/15 or 205/65/15 were stock sizes
since the e34 never came with 16" (i dont think) the closest is 225/55-16 (as tak7 stated)
you could do 205s (205/60/16) but they are a little narrow for 8" wheels (stretched a little)
The rubbing is slight enough that 1 degree of camber would make the difference. Are you as low as me? You may not even notice the rub...look on your strut towers just below the spring perch. I'd bet it's bare metal. You can also look at the inside of the front tires. There will be a smooth ring where it rubbed.
The car is stock ride height since it's gonna be donating it's 5 speed trans, lsd, and other necessary driveline parts to my Touring--which is also stock height since it will basically be my wife's car.The rubbing is slight enough that 1 degree of camber would make the difference. Are you as low as me? You may not even notice the rub...look on your strut towers just below the spring perch. I'd bet it's bare metal. You can also look at the inside of the front tires. There will be a smooth ring where it rubbed.Comment
