Dear rear shocks:
  • Nick_S
    • Apr 2011
    • 3656
    Dear rear shocks:
    Go F*#k yourself. I tried to be civil with and use the right tools and gentle, but forceful bumps with a 2X4 and a mallet but you weren't having it. 5 hours with a 4lb sledge hammer, lots of PB blaster, a heat gun, more swear words than I've ever uttered in my entire life, lots of sweat, some blood...no tears, that shit's for women. Finally I won the battle. Go to hell and take your crappy SLS with you.
    All this work and less than 10 min to reinstall both side with the new hardware:blowup:
    No point to this thread, just a rant. Carry on :drink:
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
  • slammin.e28
    שמע ישראל
    • 12054
    Looks like you've got some shitluck.
    • frankenbeemer
      • Sep 2009
      • 2260
      Price shipped to 29630?
      Don't buy an e30
      They're stupid
      1989 325is Raged on then sold.
      1988 325 SETA 2DR Beaten to death, then parted.
      1988 325 SETA 4DR Parted.
      1990 325i Cabrio Daily'd, then stored 2 yrs ago.
      • Nick_S
        • Apr 2011
        • 3656
        tree-fitty
        05 Honda Pilot
        24V swap thread
        • lolcantturn
          • 4588
          can someone explain why these are a pain in the ass?
          Originally posted by TSI
          OEM+
          • slammin.e28
            שמע ישראל
            • 12054
            I had to ditch a set of Billie sports on an e28 because the shock got rusted to the trailing arm. Removed the bolt, no problem, but the shock and arm were as one. Couldn't use heat. More force would have made them look like OP's shocks. So I left them on the car.
            • Nick_S
              • Apr 2011
              • 3656
              Mine were original with 248K miles. All the bolts came right out no issues but the metal sleeve that inserts into the trailing arm was seized. What I basically ended up doing was beating them till the bushing let go leaving just the sleeve stuck on. With just that you can get vice grips and wiggle it out or hammer it till it starts to loosen up. I would have liked to burn out the bushing but it's very close to the CV boot and I didn't want to damage that. I applied a good amount of anti seize when I installed the new ones as I'd like to get lowering springs and don't want to destroy my new bilsteins.
              05 Honda Pilot
              24V swap thread
              • South26
                • Jun 2011
                • 856
                next time use a pickle fork to get them off. I have removed a lot of these from e28s and never had a problem since I started using a fork.
                Andy
                • Xat1cZ
                  • 2020
                  wow, you really fucked them up, congratulations.
                  • Nick_S
                    • Apr 2011
                    • 3656
                    Andy
                    I did, its what i started out with. Had little success.
                    Thanks, im really strong.
                    05 Honda Pilot
                    24V swap thread
                    • Nick_S
                      • Apr 2011
                      • 3656
                      Not that it matters. Forgot to add, while doing the shocks I made a pleasant discovery that the PO had replace the sub frame and nearly all the bushings in the rear end with poly bushing. One less hassle I'll have to deal with!
                      05 Honda Pilot
                      24V swap thread
                      • TrentW
                        • 2815
                        SLS be damned. Glad mine didn't have it.
                        • M-technik-3
                          • 18946
                          Great Thread.
                          • makaveli2k
                            • Oct 2007
                            • 43
                            A two prong puller works wonders and has both sides off with ease in 15 minutes.
                            • Nick_S
                              • Apr 2011
                              • 3656
                              Tried that after the pickle fork did nothing. Violence was the only solution.
                              05 Honda Pilot
                              24V swap thread
