'94 BMW 540i V8
  • mcmahonbj
    • Jul 2013
    • 28
    '94 BMW 540i V8
    1994 BMW 540i M60B40 Automatic
    Black
    Black/Grey Inteior
    Wood Trim
    -252,000 on chassis
    -140,000 on motor
    -Unknown on Tranny
    Need:
    Subframe Bushings
    Diff Mount Bushings
    Fuel Filter
    Oil Filter
    Cabin Filter
    Coolant Flush
    Spark Plugs
    Giubo Disk
    Driveshaft Center Support Bearing
    Valve Cover Gaskets
    Intake Manifold Gaskets
    Water Pump
    Fan Clutch
    Power Steering Lines
    Valley Cover Gasket
    Thermostat w/ Housing
    Tranny Fluid Flush
    Diff Fluid Flush
    Engine Mounts
    Cooling Fan Shroud
    Accessory Belt
    A/C Belt
    Hood Ground Cable
    Wiper Motor
    Intake Manifold PCV Cover
    Transmission Filter
    Check Oil Pump Bolts
    Dogbones
    Sway Bar Links
    Sway Bar Bushings
    Stainless Steel Brake Lines
    Brake Pads
    Brake Rotors
    Brake Fluid Flush
    ABS Sensor (front?)
    Want:
    Coilovers w/ Camber Plate (BC, GC or BS)
    18x9.5 5x114.3 Wheels Square Fitment (yes I need adapters)
    -Either ET25 or ET35 are the two specs for wheels I've selected.
    -Final ET10 or ET20 adapter is 15mm (will have camber)
    Sway Bars Front/Rear
    Rear Camber/Toe Bushings
    Depo Smoked Euro Smiley Headlights
    Euro Red/Clear Taillights
    Depo Smoked Fog Lights
    Depo Smoked Turn Signals
    LED License Plate Lights
    Rieger Roof Spoiler
    M5 Rear Plate Filler
    Raceskids Skid Plate
    Euro F/R Bumper Trim
    Hood/Trunk Emblems
    Front License Plate Delete Panel
    BMW Performance Aluminum Pedals
    Alpine Headunit
    Alpine Speakers
    Kicker Subwoofers
    Door Sill Plates
    BMW Nardi Woodline Steering Wheel
    Wood E-Brake Handle
    Cup Holders!!!!
    Window Tint
    New Molding Trim and Clips (front doors/fenders)
    Cons:
    -All doors have rust on the bottom
    -Wipers don't work (motor?)
    -Rear Right Window INOP (unk)
    -Front Right Window Off Track
    -Reverse Lights INOP
    -Driver Fog Light INOP
    -Possibly Tie Rods
    Pros: ??
    -New Battery
    -New Radiator
    -Bilstein Shocks
    -Very Clean Interior
    -Front Lip (unk model)
    -Smoked Taillights (removing)
    This will be my daily driver and would like to replace all the normal maintenance items to make sure it is caught up.
  • Nesset
    • Mar 2014
    • 672
    (E34) 540i is arguably the best BMW daily driver in my opinion.. Lovely cars, even fun when on their last legs somehow... Maybe it's the intoxicating sound.
    -1976 2002 daily (Sold)
    -1986 528e 5 speed daily
    • 90-E34-M5
      • Sep 2015
      • 21
      I modified my M60B30 with a NASCAR style Y pipe underneath , have a listen
      The car is now a 540/5 speed and sounds even better
