low engine oil message
  • randompost99
    • Feb 2017
    • 1
    1992 525iT
    186k miles
    I changed the oil about 700 miles ago. The car tells me that the engine oil is low but not all the time. I checked the oil and its fine. Is this common?
    I also get the low coolant, but thats fine as well.
    88 545is, k27 Turbo, TCD Turbo Chip, 30lbs Injectors, b35 cam, Aftermarket Intercooler, Custom 3" to Dual 2.5" Exhaust, HRs/Sports, BBK, SS Lines, 18" Staggered Alpinas, 235/40-265/35 Falkens, S2.93.
    __________________________________________________ _
    Watch Fifty Shades Darker (2017) online | Watch The Lego Batman movie online
  • noypi2
    • Jun 2014
    • 442
    Check if the oil level sensor by the oil pan is connected.
    Sent from my iPad using Tapatalk
    • AndrewBird
      The Mad Scientist
      • 11898
      The connector often gets cruddy and the plastic breaks down. Likely a bad connection.
      The coolant level could be a bad sensor, but they also get gunked up and can read incorrectly (it's just a float switch).
