1991 e34 auto trans options?
  • mbonanni
    • Sep 2011
    • 6236
    Hey guys,
    My dad has a 1991 e34 525i that has been sitting for a bit due to a slipping tranny and he really wants to buy a spare trans to fix it. I read the '91s auto trans are specific to that year, and I have been having trouble finding a trans from a 1991 e34. Does anyone know the validity of this statement, so I can possibly expand my search criteria?
    My friend has a 95 ZF auto trans from an e36 M3 I can pick up for super cheap, will this work? What other year transmissions will work, if any?
  • DesertBMW
    • Aug 2011
    • 1036
    1991 has A4S310R (GM) transmission, same as any 1991-1995 525i. they are everywhere and easy to find.
    • mbonanni
      • Sep 2011
      • 6236
      That is good news, thank you. So what about this? Says they also came with ZF5HP18? Which is what came in the auto e36 m3's correct?
      Obviously I know wiki isn't the best source, but other websites say the same. Notice how it doesnt include 1991 for the 5HP18 though, why wouldnt it fit the 1991 m50?
      • DesertBMW
        • Aug 2011
        • 1036
        What tranny do you have now?
        • mbonanni
          • Sep 2011
          • 6236
          Not sure, car is kept an hour and a half away and I haven't had the time to drive out and lift it up to find out. However, given that is probably the best option to figuring out what I need I will try and find some time to do so. Howevver, does anyone know if I can use an auto trans from a 1995 e36 m3, I have access to one so it would save me a trip if someone knows the answer.
          Do the gm and zf trans have a different bolt pattern, are they interchangeable? Cause if not that would mean the block on the m50 changed depending on what transmission it came with?
          • PorscheH6
            • 242
            It's possible, but it's a lot more work. 5HP18 came on european and other ROW M50 E34 models, but not in the USA. Chances are it may bolt up if it has a 6cyl bellhousing and not V8. You'll need a different driveshaft and transmission control module at a minimum, possibly even the shifter mechanism.
