Steering noise
  • Lucas.B
    • Jul 2005
    • 115
    Steering noise
    Hey Guys,
    After I lowered my car I get a clunking noise in the front when steering at low speeds. No noise if the front end is jacked up. Any ideas?
    Thanks so much
  • Adrian_Visser
    • Jun 2006
    • 2823
    balljoint(s)
    '89 Alpine S52 with goodies
    • Lucas.B
      • Jul 2005
      • 115
      So new control arms are in my very near future?
      Thanks by the way!
      • gazellebeigem3
        • Jun 2005
        • 3712
        Did it start right after you lowered the car or are you just tossing that in there? If it happened right after, i would check that you assembled the struts correctly and that everythings tight.
        • gearheadE30
          • Jun 2007
          • 3734
          Lowered cars tend to go through ball joints a bit faster than stock because there is more load on them and they are outside of the designed articulation range depending on how low you are, so they may be shot.
          Project M42 Turbo
          • Lucas.B
            • Jul 2005
            • 115
            Ok thanks guys
            Yeah, it start right after I lowered it. Maybe they were bad before had and lowering the car just put enough stress on them to start making that noise?
            I went back and checked the strut assembly, everything looks ok, maybe the spring is a tiny bit off or something?
            I'll check again.
