Throttle linkage went to "cruise control mode" ;)
  • thornado327i
    • Oct 2006
    • 501
    So I'm driving home from my uncle's place (app. 60miles), and after just few miles my car started going by itself - felt like I had cruise control - you let go of the gas pedal, and the car keeps its speed - funny.
    Being a clever guy I found a place to pull over, to check WTF is going on before it would brake on the road. I discovered throttle cable housing to break just by the firewall, causing the cable to bend an get stuck at one point.
    After toying with it for a while it broke (must have been bent for quite a time).
    And so I'm stuck in some sort of village with the problem.
    Sure - my uncle has some parts, BUT since he always makes fun of me having a 20yo car, that would be the last thing to do.
    Then spotted couple of guys on quad bikes having a meeting of some sort. So I went up and asked whether they had a steel cable of some sort. One of them went home and brought me a broken motorcycle clutch wire - was broken at one end and had a perfect stop at the other.
    I asked him for a nut and bolt to make the stop at the other end. Having that, I ripped the cable housing out, run the clutch cable, wrapped it around the gas pedal lever, and used bolt and nut to make a stop.
    Got home no problem.
    Went from "damn car! I hate you!" mood to "I love you for your simplicity" mood.
    Just a story to share ;)
  • accident
    • 7303
    bravo sir.
    Moral of this story?
    • dashboardmonkey
      FUCK YOUR WAFFLES
      • Jun 2008
      • 6158
      Ingenuity is a must when owning an E30
      -Andy
      • reccaoconnor
        • Dec 2008
        • 29
        i hear mcguyver learned the tricks of his trade from owning an e30.
        • AndrewBird
          The Mad Scientist
          • 11898
          Very nice.
          On my MG once, I lost the center carbon rod out of the distributor cap. Ended up cutting a piece of throttle cable housing and using that in it's place. Worked good and got me home.
          • Naplm00
            • Nov 2008
            • 1573
            check out my old thread about this same shit
            my suggestion is replace the whole cable assembly, its only 20 USD
            88 325ic ~~~> Rusty and ugly
            85 E ~~~> RIP
            • BillBrasky
              • Dec 2008
              • 1641
              They were probably changing a bulb.
              • thornado327i
                • Oct 2006
                • 501
                http://www.r3vlimited.com/board/showthread.php?t=128987
                Yeah! I searched for similiar problems and found it - thumbs up for creativity!
                Done. But now I miss my ghetto cable fix ;)
                • Dillinger
                  • 285
                  Very cool, MacGyver tricks. I drove one home on kite string run up under the hood and through the window once.
                  • Franken30
                    • May 2008
                    • 71
                    ^brilliant fix --- LMAO. Kite string. Man - I bet that thing "flew" after that. : o )
                    • thedeal
                      • 643
                      I had a similar issue on my e30.
                      My throttle cable was literally on its last threads so i replaced it. While replacing it the clip that holds the cable to the throttle linkage must have cracked. Couple hours later I lose all power, Plastic clip (bearing as BMW parts calls it) is totally missing. I take out an old library card, cut it to the right shape, punch a hole in it and cut a slit from the hole to the edge of the card. I slip it over the throttle cable, with the tension from the cable and a bit of JB weld, it ran. Used it for a week until I had the time to pick up a new part. MacGuyver skills to the rescue!
