What is this plug? Located behind the cluster
  • Bimmerista
    • Nov 2005
    • 5425
    Pulled my cluster to paint the needles red and replace the speedometer. There was one plug that was loose and I did not pull it from the cluster. Does anyone know what it is and where it goes? My speedo, tach, gas & temp gauge all work fine.
    The only thing that does not work is the odometer & trip, which didn't work to start out with. Any inputs??
  • SamE30e
    • Sep 2007
    • 4319
    For 16 button OBC?
    1985 325e 2.8 Turbo VEMS
    • Bimmerista
      • Nov 2005
      • 5425
      OBC works fine...registers info as it should.
      • Adrian_Visser
        • Jun 2006
        • 2823
        16 button obc?
        '89 Alpine S52 with goodies
        • EricT
          • 702
          Time circuts??????
          BUT THIS!!!!! http://www.r3vlimited.com/board/showthread.php?t=194272
          • gazellebeigem3
            • Jun 2005
            • 3712
            flux capacitor
            • Dillinger
              • 285
              The gong module? The CC?
              • Bimmerista
                • Nov 2005
                • 5425
                Nope, nope, & nope...
                • TwistyTunedE30
                  • Jan 2005
                  • 499
                  Do your power mirrors work on the driver side...thats identical to the plug that runs into the door
                  • Bimmerista
                    • Nov 2005
                    • 5425
                    I'm certain it does. But the thing is, this wire is all the way behind where the cluster. Just seeing how long it is, it would seem that it attaches someplace behind the cluster. Its not long enough to reach to the door.
                    • Liam
                      • 753
                      Not the mirrors, not a plug for the cluster.
                      I don't know what the hell it is, BMW OEM plugs don't index like that.
                      Abandoned aftermarket alarm shit?
                      I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
                      • TwistyTunedE30
                        • Jan 2005
                        • 499
                        was your car an airbag car
                        • Liam
                          • 753
                          SRS plugs are ALL orange (It's the law... Or at least it was the law).
                          • TwistyTunedE30
                            • Jan 2005
                            • 499
                            im just thinking that something in the steering column or something in that area came unplugged as all that stuff is pretty flat that runs up through there...just a thought though im stumped and so is bentley's
                            • Bimmerista
                              • Nov 2005
                              • 5425
                              Nope...its an 88, no airbag.
                              Also, no aftermarket alarm type electronics in this car.
