E30- S65 Swap and 3D Scanning
  • raceablestreetcar
    • Mar 2019
    • 20
    Originally posted by Panici
    Ah, so the subframe is hard-mounted to the chassis, and then there is a poly mount on the engine arms?
    Correct, it is solid mounted to the chassis in the same 4 locations as the OEM crossmember, and there are the two additional mounts where the lollipops used to be. The poly mount is tough to see but it is where the engine and crossmember meet, similarly to the OEM system, just a bolt through mount instead of a pedestal style mount.
