Auxillary Fan bypass for Constant High
  • AmosCake
    • Feb 2021
    • 218
    How do I wire the resistor to have the fan running on high only? Do I just move the wire to the other side of the resistor. If so, which wire do I move to where?
  • prisonerofdoom83
    • May 2013
    • 529
    I just did this on boy my cars . One side has two wires the other side has one wire . Take the red wire from from the side that has two and connect it on the side that has one . Leave the other off . I think you have to upgrade the fuse to 30amp . I think even if you mix them up (I did) it will just pop the fuse . If so just switch them
    • AmosCake
      • Feb 2021
      • 218
      Bless the best explanation ever. Thank you so much
