How to increase throttle response?
I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true". -
I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".Comment
Probably not, I don't have my own dyno and have to drive way to hell and gone to borrow my buddies.
Not a lot of point in spending a bunch of resources on these old ones, maybe latter down the road though if the opportunity is there.I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".Comment
my cammed 2.5l m20 hasa pretty bad off idle stumble too especially when cold, since it was cammed before i got it i've never been sure if it was because of the cam or a problem with the engine
'89 Alpine S52 with goodiesComment
Let's make this an easy answer: afm is mechanical vs. maf is digital,and that in it self is a difference,throttle response, one can't argue that as far as the horsepower one will gain? I say put it in do a dyno test.Then you will have paper work in had for proof rather than get 10+ different answers which all can't be correct, and I have heard all good things not one thing bad from the people that have used it.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
So it took about 30 minutes to install (probably an hour and a half without a full shop and many years experience doing this kind of thing).
The AFM this replaced was about 6 months and 1000 miles old. Everything on this engine is pretty much 100% fresh.
Right off the bat, definite improvement. Smoother idle and no bounce when the throttle gets "tapped" in overall drive-ability there is a very noticeable improvement in throttle response and the subjective ass dyno tells me that it's gained some torque and a wider power band.I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".Comment
I only tossed it in this afternoon and drove it to get coffee.
I keep pretty tight records on this car so after a little while I'll have information on general fuel economy and more (albeit subjective) information from driving it in different conditions.
And yes, if I get a chance, I'll run it on the dyno and then will have some comparison from the last time we ran the car with the AFM.
After that... I have some evil plans (it'll be a while though).I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".Comment
Good info, thanks for sharing. Did the car already have a performance chip? Are you running larger injectors or any other little bolt-ons?Right off the bat, definite improvement. Smoother idle and no bounce when the throttle gets "tapped" in overall drive-ability there is a very noticeable improvement in throttle response and the subjective ass dyno tells me that it's gained some torque and a wider power band.Comment
Well yes.
It is not "stock" an awful lot of things have been changed not necessarily just bolt on stuff either, it was dialed in on the dyno prior to this being slapped in.I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".Comment
I just saw this, was thinking about it, but guess I don't really need it. I wouldn't mind a flywheel honestly. The car doesn't rev as fast as I want like my 350z does. :(sigpicComment
