Replacement Part
  • joshanoya
    • 164
    Replacement Part
    anyone know where i can get these mounting brackets? mine have two broken teeth for the upper and lower bracket. i think i found number two over at PelicanParts but someone double check me on it cuz im not sure if its the same. and also i cant find number 1 anywhere so if anyone knows where i can get these it would be greatly appreciated :)
  • ethree
    • Aug 2007
    • 1216
    The junkyard?
    • joshanoya
      • 164
      Originally posted by ethree
      The junkyard?
      thats an option but i was hoping to get these brackets new.
      • Jean
        • 18228
        Find the part number on realoem or bmwfans.info and order it. I had no problem ordering it last year for the same reason ;)
        • joshanoya
          • 164
          AHH thank you !
          • jp_slick
            • 1089
            I busted those same brackets a few days ago, a quick trip to the junkyard did it for me
            89 325i S50/ZF E36 M3/TI 5lug Style 32s
            My feedback Thread http://www.r3vlimited.com/board/showthread.php?t=219113
            • nataku83
              • 23
              i just bought #1 off pelican, it's the part you listed, despite it not looking correct in the picture (it's straight in the picture, angled in real life...). spring for new bushings while you have the alternator off, mine were toast. #2 is the power steering tensioning bracket, i don't see it on pelican.
              '85 323i (~165k), '90 Miata (~194k), '81 CM200t (~18k), '84 VF700s (~29k)
              • xLibelle
                • Aug 2004
                • 2673
                you need to be using www.realoem.com for the part numbers, make a list and email or read it to pelican or BMA
                i've used realoem to help me put stuff back together too, thats how much i use it
                • NC325iC
                  • Mar 2004
                  • 6565
                  bavauto sells them new
                  • joshanoya
                    • 164
                    thank you very much :D
                    • Naplm00
                      • Nov 2008
                      • 1573
                      yea they are cheap new..and nice and shiny!
                      88 325ic ~~~> Rusty and ugly
                      85 E ~~~> RIP
                      • tcheb
                        • Jul 2008
                        • 619
                        One piece of advice, if you put on a new bracket, get the little gear as well. They get worn pretty easily.
                        • nataku83
                          • 23
                          heh, great, just discovered last night that I need the PS bracket as well... Anyway, if you're in a bind and just want to get the car going, I found you can just push down on that bracket (on the outside edge, with the mounting nut loose) to tighten the belt, and then tighten the adjusting nut while you continue to apply pressure to the bracket. I was able to get the belt pretty tight that way, and it'll hold me over until I can get that bracket.
