Air Control Valve?
  • e30tyro13
    • Apr 2009
    • 43
    Air Control Valve?
    I have an 89 325i and the car is revving itself, i thought this was normal when I turned the car on. but i was on a red light and it started to rev it self again and the check engine light came on. As soon as the light turned green and I accelerated. The car started shaking and it turned off, my mechanic said the idle control valve could be the problem.
    what do you guys think?
  • e30tyro13
    • Apr 2009
    • 43
    Just changed the air control valve.
    still revving like crazy.
    anyone want to help?
    • xLibelle
      • Aug 2004
      • 2673
      Idle control valve??? no, not your issue. ....something up with fuel supply?
      • e30tyro13
        • Apr 2009
        • 43
        i guess i have to look into that
        • e30tyro13
          • Apr 2009
          • 43
          bump
          Need help
          • olskool
            • Mar 2008
            • 77
            Had the same problem. Also thought the ICV was the culprit, but it turned out to be a bad ECU. Put in a new ECU and problem went away.
            • e30tyro13
              • Apr 2009
              • 43
              how much does a new ECU cost?
              • Naplm00
                • Nov 2008
                • 1573
                depends on the model..seach for it
                88 325ic ~~~> Rusty and ugly
                85 E ~~~> RIP
                • SpecM
                  • Oct 2005
                  • 4531
                  psssh, get a used one, $40-50
                  but your problem sounds like a vacuum leak to me
                  1989 cirrisblau-metallic 325i
                  • RickSloan
                    • 2401
                    i agreed bad bad vacuum leak sounds like the problem.
                    start the car and while its surging, pull off the oil cap and see if anything changes, it it doesn't then you have yourself a bad vacuum leak
                    Need Illustration or Design work? www.robbiebyerly.com
                    • Jesse30
                      • Jan 2007
                      • 3936
                      if you want to try the ICV i have a known good one i'd be willing to sell cheap.
                      • Philo
                        Ich esse kleine Kinder
                        • 3334
                        +1 for the vacuum leak.
                        -tim
                        Originally posted by Jordan
                        I like the stance
                        • e30tyro13
                          • Apr 2009
                          • 43
                          lets hope thats it
                          if not
                          might have to sell the car :(
                          • Philo
                            • 3334
                            Easily discouraged eh?
                            -tim
                            I like the stance
                            • Maluco
                              • Oct 2005
                              • 6572
                              general disgution?
