warning lights
  • Dlazy
    • Jun 2026
    • 1
    warning lights
    Hello!
    What would be the cause of 3x warnings on start up? ABS/Brake fluid/battery
    Only on idle. If i rev it up once it goes away for the rest of the ride.
    Any ideas?
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5609
    low voltage at idle
    probably a worn voltage regulator on the back of the alternator.
    if you haven't done it before, its simple.
    disconnect battery, remove air box and remove the two screws and flip it out. you don't have to take the whole alt out. (assuming its some m20)
