dinan e34 m5 motor to e30 swap
  • joehasane30
    • 303
    alright guys, really random but i actually found a dinan e34 m5 with good everything except it was crashed in the back. Was curious if even possible or if anyone has put a motor from a m5 like that in an e30. I mean the car is basically free just need to tow it and i think it would be badass if i can swap that motor to my car. Also what parts if any besides the motor can i swap from that car onto mine, 5 lug swap? if anyone knows anything please lemme know, thanks!
  • e30s52
    • Oct 2007
    • 5235
    search. But yeah the swap can be done just not the 5 lug.
    www.gutenparts.com
    • joehasane30
      • 303
      i dont have a computer, im using a ps3 to go on the internet with no keyboard. Not very easy to search with. Cant really find anything either. I took the owners manual out of the m5 tho when i saw it. It says it has a 311hp, 265trq, 215cu.in. inline 6. I know the 535i is a 206cu.in. motor. Is the m5 motor just a bored out 535i motor? Also i have another question, the m5 is a dinan m5, what exactly does dinan do to the car? Last question, does the 535i motor fit in to e30 easily?
      • e30s52
        • Oct 2007
        • 5235
        Yes those mounts fit but you have to get diffrent motor mount arms. Dinan mostly just sells go fast bolt on parts for the most part. Where did you find this m5?
        www.gutenparts.com
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          Address of said m5? I'll go"check it out" for you.
          • Jesse30
            • Jan 2007
            • 3936
            yes it will fit. in theory yes the m5 motor (s38) is a m30. buy it and stuff it in there.
            • James Crivellone
              Head Janitor
              • 6304
              I also have a dinan 93 m5 i'm taking the motor from.
              Issues you will run into
              Engine mounts, tranny mounts, exhaust, custom driveshaft (although I've heard some combo's will work)
              The biggest issue is the front subframe, which needs to either be heavily modified, or lowered about 15 - 20mm, otherwise you cannot clear the plenum.
              Second issue is brake booster clearance, which I'm getting around buy using a modified e34 540i remote brake booster.
              • joehasane30
                • 303
                damn, you guys have no idea how stoked i am to hear this. Sorry cant tell anyone where it is cause its mine!! but i will be sure to start a thread about my entire swap if i go through with it. Ill also put some pics up once i get to an actual computer, not a ps3.
                • joehasane30
                  • 303
                  those are all issues ill have no problem with, have you started the swap yet? how far along are you?
                  • joehasane30
                    • 303
                    so this car probably just has different exhuast then a regular m5, maybe few other things and a dinan label?
                    • James Crivellone
                      Head Janitor
                      • 6304
                      still in research mode, planning to begin some time after summer.
                      Few other things you need to keep in mind.
                      Read up on the S38 and what it requires. I hope you found a low mileage example because things start to really add up as the engine gets older, things like timing chain guides, misc oil leaks, etc really add up the cost of the motor.
                      If the engine has over 175K on it, I would check every piece before putting it into the car, and work from there. If you have a chance to snag up any spare S38 parts you should certainly do it, heads alone can fetch over 3000 - 4000 once rebuilt, and if you are talking about the entire engine it can take over 10 grand to rebuild it to near factory spec.
                      And finally, also check into what oil you plan on running, something high in zinc is a good place to start. Don't plan on running anything off the shelf at the local autoparts store.
                      Remember, the S38 is the last of BMW's raw ///M motors, so things are designed with VERY specific tolerances.
                      That being said, the motor is a work of art, and when its running properly it is still one of the best damn inline 6's in the world.
                      • joehasane30
                        • 303
                        this would be an awesome project, but what kind of money can i get out of selling that motor?
                        • e30s52
                          • Oct 2007
                          • 5235
                          Depends on the condition, etc. I will buy it though depending on the condition.
                          www.gutenparts.com
                          • e30s52
                            • Oct 2007
                            • 5235
                            Or maybe trade you my s52 for it.
                            www.gutenparts.com
                            • joehasane30
                              • 303
                              well im going to hopefully carfax the car soon. Actually i really have no idea how to go about getting the car, i literally found it, no owner, no nothing, all i have is the VIN. I dont want to just take it because it may have been stolen, its been sitting behind my friends warehouse for about 3 months.
