green brake fluid
    green brake fluid
    was helping a friend who recently got a bmw, we were bleeding the brakes, the color is green. Im used to seeing clear with my castrol or others ( or real pale yellow)
    I hope this is not synthetc as I was told dont mix them and when you get syn in them you always have to run syn as the two will interact and not function correct
    true?
    thanks
    fuck yah
    85 318is \\\M
    up date mods:
    roundel subscription
    mega time attack bottlecaps
    extra cut springs
    wiper blade delete
    racing slick tires
    nite-shadez headlights tail lightsmand windows
    xtra mods:
    cut belt
    sanded spark plug
    air filler delete
    even more cut springs
    broken ac delete
    more:
    more cut belt
    bettered:
    crome fender trim
    crome spray nozzle
    cut off exhost
    body color grillz
    ran bumbers n2 wall
    blue under body lites
    neon wheel wells an calipurs
    new:
    eyebrow
    black gills
    more head lites
      no, that's BS
      all brake fluid is "synthetic", btw
      1989 cirrisblau-metallic 325i
        $5 says its coolant
          Probably a dye used by whomever makes that brake fluid to make it easier to spot leaks.
          If it bothers you flush the system and replace it with some BMW approved DOT4.
          As long as it doesn't come out black and full of metal shavings you're fine.
          I think you're confusing advice about motor oil with advice about brake fluid. It doesn't matter anyway. You can mix syn and non-syn motor oil as long as the viscosity and API/SAE ratings match; and even if they don't it's not a big deal. Once you use synthetic you can go back to regular, or vice versa.
          The Keystone Killers
          With 73k+ post, you'd think he'd have learned a little about life.
            or dark brown/rusty thats bad
              HAy GuYs I lEfT tEh Cap OOf mAi ReSevoR fOr 2 WeAks, it Dat Bad? :)
              Edit: VVVV DOT5.1 mixes fine, DOT5, DOT3 do not mix with DOT4. VVVV
                green tint probably means it had SuperBlue in it at one point, and now had gold. SuperBlue stains everything, and any subsequent changes will have a greenish tinge to them. I alternate between blue and gold just to make it easy to tell when I'm done.
                And yes, there is a DOT5 brake fluid that you should not mix with DOT4 (what you should use for these cars)
