Need advice removing rack from rack housing
  • Flash
    • 688
    I am trying to remove the toothed shaft from the housing but am down to the last part, im assuming those little ring-halves need to be rotated or punched out?
    I just need to extract the toothed section but am stuck now :(
    Any advice is appreciated.
    Thanks!
  • xLibelle
    • Aug 2004
    • 2673
    rotated. its not two halves, its one threaded ring with two places cut out for a spanner wrench. I ended up making my own spanner to fit that.
    There are a couple weld spots that youll want to file or dremel off before attempting to remove that threaded ring.
    Easiest way to get it started rotating is with screwdriver and hammer
