I bought an e23 a while ago, in good working order. It took a while to start occasionally, but it fired up, and everything worked. Turns out I bought a lemon- car won't start now, and only blows air through dashboard vents. I took it to a shop and had them look at it. It started right up for them with some starter fluid, and continued to start. However, it was very reluctant to start when parked uphill slightly, and would occasionally die on the road. (car was picked up, moved to my new house, and parked.. won't start now.)
My thoughts:
I'm guessing I'm not getting fuel, particularly at startup before the fuel pump has a chance to build pressure. So, either my fuel filter is clogged (I am going to replace anyway), my fuel pump's going out, my fuel pressure regulator is on the way out, the fuel lines are clogged, or it's a fuse/relay problem. Fuses are new, relays are not. I'm going to start with the fuel filter and relay and hope that solves the problem. Any other thoughts?
My thoughts:
