Alright so do any of you have any ideas on how to SAFELY pull out the little trim piece that sits above the front bumper and below the grille?? I can see that its not just a 'little trim piece' and in fact goes down and behind the bumper.. which will probably require a good amount of controlled force. Maybe tie a rope to my buddies 325 and the other end to that piece and heat up his clutch a little bit?? Ideas?
An interesting dent
That little thing is a bitch, body shop could barely fix it for me when I got in an accident. Thats the only part of the car thats still fucked up -
That piece is part of the valance. It's not difficult to remove the valance but you have to take off the front bumper, grills and brake ducts.... the removal and reinstall maybe more work than it's worth.... I'm not sure how bad the dent is...
But first try this, remove the grills and the headlights and see if that gives you enough room to bang it out from behindComment
That thing is connected to your valence below IIRC. If you remove that, your valence goes with it.
