Cracking a trunk lock
  • tehwickerman
    • Dec 2008
    • 1088
    Theres a car in a junkyard with some nice shocks I'd like to get my hands on but the trunk is locked so I can't get them off unless I drill them out which may be very difficult... Is there any trick I can use to crack the lock?
  • StereoInstaller1
    GAS
    • 22679
    Yes.
    Find the white and blue wires that go from the central locking module to the trunk.
    Grab a handy 12V source,(electric screw gun battery is the #1 choice) cut those wires, and apply power to them for just a second.
    If it does not unlock, reverse the polarity on the wires.
    If this doesn't work, you're fucked.
    Closing SOON!
    Thanks for 10 years of fun!
    • TexasTerp
      • Jan 2009
      • 3541
      That's really interesting, I never thought of that before.
      stephenbrody.com
      • StereoInstaller1
        GAS
        • 22679
        I use the same trick to roll down windows.
        Closing SOON!
        • kronus
          • Apr 2008
          • 13029
          Yes.
          That is awesome, thanks Luke!
          You're not boned if that doesn't work, though. I was stuck in a similar situation... Since I did not know about this trick, I bent up the lip of the trunk enough to be able to get a wrench under there. From that position, you can undo the two 10mm bolts that hold the latch to the trunklid.
          cars beep boop
          • tehwickerman
            • Dec 2008
            • 1088
            Awesome thanks guys. I don't think the car has central locking so it looks like I'll be doing some bending.
            • StereoInstaller1
              GAS
              • 22679
              99% of all BMWs in the US came with it.
              Closing SOON!
              • RobE30
                • 959
                Cordless sawzall is fun too;)
                09 BMW 328xi touring 6spd
                05 Subaru Outback XT 5spd
                87 BMW 325is
                a few bicycles
                • emi325i
                  • Oct 2006
                  • 356
                  I unlocked mine old-school style using a hanger wire through the license plate hole. I used my other e30 as a test subject to practice and calibrate the "tool". You may need to let a genuine eastern-European perform this procedure, tho.
                  • Stevie30
                    • Apr 2007
                    • 1534
                    Try this:
                    03-22-2009, 08:16 PM #18 Stevie30
                    Images: 19
                    I had the same problem on my '91 vert. If you will disassemble the lock on your other e30 you will see how you can get to the latch. Note the screw in the photo. This is where i drilled a hole big enough for a coat hanger wire to actuate the lever arm and open the trunk. After you get it open, remove the electric actuator and your lock should open manually with the key. Don't close the trunk lid until you are sure the key will open it. If it doesn't you can always use the coat hanger wire to open it. I put a small self-tapping screw in mine to fill the hole.
                    1991 325ic and 1991 318is
                    • ak-
                      • 12422
                      Jaws of life work well too.
                      1991 325iS turbo
                      • Chachi
                        • Sep 2006
                        • 668
                        get a long thin screwdriver and a hammer
                        had to do this on a parts car i had, if its in the junkyard who gives a fuck! it worked for me on about the third hard hit, i guess it broke all the tumblers and just popped. i felt like the fonz for a second
                        Originally posted by blunt
                        i called my 17 yo paperboy "sugartits" in a christmas card 3 years ago. he never came back and im not joking.
