How To Sea Foam
  • BTP325ic
    • Apr 2009
    • 700
    How To Sea Foam
    ok so i just bought some seafoam for my 84 ETA it has 217k on the rack as we speak.its my first time using this and i saw this vid below explain how to use seafoam, i have heard good and bad about seafoam and i was wanted to hear other peoples experiences with seafoam.thanks
    brice:)
  • e30slut
    • May 2008
    • 793
    theres a bunch of threads with instructions and results...
    searching is your friend and keeps you from being flammed....
    • BTP325ic
      • Apr 2009
      • 700
      ok
      • e30slut
        • May 2008
        • 793
        and just to get you moving
        • BTP325ic
          • Apr 2009
          • 700
          thanks
          • Jand3rson
            • 37587
            1. Open can
            2. Dump contents down drain
            3. Piss in can
            4. Proceed with instructions for use
            It will do the same amount of good. Your car will feel better for about 2 weeks, then feel about the same as before, if not worse. I ran 2 cans of this stuff through my engine last summer, and when I pulled my head this winter, the underside of the head and the tops of the pistons still looked like absolute shit. Total waste of time and money.
            • e30slut
              • May 2008
              • 793
              it really only kinda sorta cleans the O2 sensor... temporarily....
              • TexasTerp
                • Jan 2009
                • 3541
                If you want to do a real engine flush and treatment, get the Lubro Moly system from BavAuto for $100. It's a multi level system but it will actually clean out your system.
                stephenbrody.com
                • BTP325ic
                  • Apr 2009
                  • 700
                  dam sounds kinda expensive have you used it before?
                  • TexasTerp
                    • Jan 2009
                    • 3541
                    The system includes 6 Valve Cleaner Additives, 6 Fuel Injection System Cleaners, 1 Engine Flush, and 1 Motor Protection Additive.
                    You can buy each thing individually. I've used the entire system and it has completely stripped and cleaned my system completely. The biggest issues with running engine flushes like Seas Foam and Lubro Moly is the risk of clogging the system.
                    With the Lubromoly there are separate systems that take longer to work but are better for your system in the long run. I've used the system twice in 22 years of owning my e30 and it's fantastic.
                    stephenbrody.com
                    • BTP325ic
                      • Apr 2009
                      • 700
                      i see i might check it out.
