Gave the E36 to the old ball and chain
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    So i decided to give the 1997 328is e36 to my girlfriend and i went to get it inspected.
    Turns out that since I just replaced the battery and all the CEL codes were reset, the car can't pass inspection because the car hasn't been driven for 90-120 miles for the ECU to reset. (this is true, i haven't driven it that much yet)
    Is this true? have any of you heard of this?
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
  • FredK
    • 14761
    Yes. It must be driven a few times for the OBD-II to log that all systems check out.
    If you reset it and drive it into the station, the OBD-II will say Not Ready.
    • E30SPDFRK
      • 5700
      Yup. I have to drive cars around at work all the time to set the readiness so they can be inspected. 90-120 miles is way overkill though, usually 15-20 minutes at 55mph will do it.
      Byron
      Leichtbau
      • payney8
        • Jun 2007
        • 899
        lift rear wheels off ground. chock front wheels. large brick on throttle. i dare you
        • Garageaholic
          • Dec 2005
          • 5204
          Hey guys. thanks for the comments. I have a quick update.
          Drove the car for about 500 miles (all highway) and still reads 3 codes (not ready)
          O2 Sensor
          Secondary Air
          Catalyst
          I'm going to remove the battery cable and then go for a drive tomorrow morning for about 30 minutes. See if anything transpires.
          I don't think that the catalytic converter, O2 sensor, OR the secondary air readings are causing problems becuase I got over 30mpg on that 500 mile trip...
          Wierd.
          Recent Rebranding!!
          E30 SM62/S62
          E30 M60 V8
          E30 M30 Big 6!
