need a pic of the back of a cabrio release handle
  • chasiubao
    • Mar 2006
    • 335
    I'm converting my broken auto top to manual, I've put in all the release cables and I believe the handle to release is the same as the door handle but I have 2 cams to put in it but only 1 hole in the rear....cabrio owners can I get a pic of the back of your release handle (the handle in back of the driver's side) or describe to me where the 2 cams from the release cable goes. I can't tell from real oem.
    TIA
  • doglegleft
    • Mar 2007
    • 103
    Here you are...
    • OrganicMechanic
      • Jan 2008
      • 1719
      It is the same as the door handel. I used a door handel to repair my cabrios release.
      join the E30 Cabrio owners gruppe
      click here for details
      • Stevie30
        • Apr 2007
        • 1534
        The two parts you need to connect the cables are:
        Upper bushing: 51251933472 (the upper and lower bushing screw together in the handle)
        Lower bushing: 51251933473
        Covering cap : 51181823474 (you will need 2 of these to secure the cable ends)
        They are available at your local BMW dealer. Should be about $15-20 for all the pieces.
        1991 325ic and 1991 318is
        • chasiubao
          • Mar 2006
          • 335
          AWESOME-thanks guys....
          super big help couldn't tell a thing from real oem...
          • Stevie30
            • Apr 2007
            • 1534
            Good luck. You will like the manual conversion. It works every time.
            • chasiubao
              • Mar 2006
              • 335
              the pics and part numbers are awesome-anyone have any of the upper and lower bushings available???
