Need some serious help!
  • tatertots
    • 104
    Today I took off from a stop sign shifted from 1st to 2nd at about 4500 rpm
    and all I hear is a pafff sound then the car is still but 1st, 2nd, and 3rd gears all feel like they dont exist, I cant get the shifter into 4th or 5th, and the car is somehow stuck in reverse.
    I looked under the car and the tranny seems to have some wetness on it, It feels like tranny fluid.
    Any ideas of what it could be?
    Any help would be great
    Thanks guys
  • Jand3rson
    • 37587
    Does your clutch pedal stay stuck to the floor?
    • tatertots
      • 104
      Nope the clutch still rises and has a pressure point, I can move the car in reverse
      • downernsp
        • Mar 2008
        • 1932
        Thanks guys
        If you put the car in 2nd or 3rd and car doesn't shut down BLOWN tranny nice one.
        • george graves
          • 19997
          What year is it? Is the shifter all limp?
          Originally posted by Matt-B
          • StereoInstaller1
            GAS
            • 22679
            broken shift selector rod would be my guess, and your first hope.
            Closing SOON!
            Thanks for 10 years of fun!
            • daniel
              • 6703
              pray for this
              http://instagram.com/dslovn.drives
              • george graves
                • 19997
                84-85 dirty selector plate...
                • StereoInstaller1
                  GAS
                  • 22679
                  Izzit that early?
                  Closing SOON!
                  • delatlanta1281
                    Dart Master
                    • Mar 2006
                    • 10317
                    Thanks guys
                    They are all wet underneath.
                    Hopefully it is the selector rod, or the shift plate (if you have an older model). I know that when the bushing in my shift plate went, my e28 was all but un-drivable.
                    Yours truly,
                    Rich
                    you kids get off my lawn.....
                    • tatertots
                      • 104
                      I cant put it in 2nd or 3rd the tranny is stuck in reverse.
                      Its a 1990 325I, 1st, and 2nd are all limp. I cant get into the rest of the gears.
                      How would I be able to tell if this is the case?
                      Originally posted by daniel
                      pray for this
                      I am praying!!
                      I hope so to, But why are they all wet underneath?
                      Thanks guys I appreciate all the help
                      • 92 mtechnic cabrio
                        • 4907
                        How hard were you shifting?
                        How hard were you driving?
                        The transmissions on these cars are usually pretty bullet proof. So chances are its somewhere in the shift linkage like everyone is saying.
                        R.I.P 07/01/09 - 04/23/10 :(
                        • downernsp
                          • Mar 2008
                          • 1932
                          If you can't even shift it into a gear it has to be a shifter mechanism of some sort.Try looking at real OEM to see an explosion so you can have an idea of what parts may be the isssue good luck.
                          • StereoInstaller1
                            GAS
                            • 22679
                            Climb under your car and look at the rod that connects your shifter to your transmission.
                            Closing SOON!
                            • tatertots
                              • 104
                              Thats the part that sucks the most, I was shifting normally, and driving I shifted it at 4-4500 rpm instead of my usual 2500-3000rpm
                              I will check that out, But currently 1st, 2nd seem to be really loose, as for 3rd, 4th, and 5th I cannot put the shifter into their positions it seems jammed, and the shifter sits in neutral but the car is stuck in reverse.
                              I tried to but I could not get under it far enough my jack was not tall enough, I will try again with another jack tho
                              Thanks guys
