metallic noise
  • kamotors
    • Nov 2007
    • 7102
    metallic noise
    my car just started having a weird metallic vibration noise between 1500-2000 rpms. It makes the noise in all the gears. It only makes the noise under load, in neutral its fine. I'm thinking its an exhaust shield under the car, what else could make that noise?
    7speedshop.com
  • jaye30
    • 561
    mine does the same. i cant figure it out.. i was thinkin the sway bars.
    • kamotors
      • Nov 2007
      • 7102
      hmmm, for me its does it whether I'm going straight or turning, its not speed related. Its weird because its almost always at 2000rpms, it kind of makes a buzzing thin metal kinda sound.
      7speedshop.com
      • george graves
        • 20003
        Heat shield would by guess. Not the big one that go along the tunnel, but the ones welded to the down pipes. It you wack at them with a knuckle, you should find the offending part.
        I took a hammer to mine to dis-form a bit - it got rig of what ever was vibrating.
        Originally posted by Matt-B
        • delfin
          • Nov 2007
          • 1064
          Mine also started doing this exactly. Just recently. It might be that the cat is dying.
          Advanded Delphin Division
          My e30s: 1987 325i/1994 318iT
          • AndrewBird
            The Mad Scientist
            • 11898
            Your center support bearing might be bad. How bad is the vibration?
            • kamotors
              • Nov 2007
              • 7102
              no vibrations, also my cat is only about 1 year old.
              7speedshop.com
              • daniel
                • 6703
                on car talk they always say the noise is caused by this.
                http://instagram.com/dslovn.drives
                • kamotors
                  • Nov 2007
                  • 7102
                  guess I'll start looking around under the car, too bad my jack doesn't work with the car lowered:(I'll just drive onto some bricks and start looking.
                  7speedshop.com
                  • delfin
                    • Nov 2007
                    • 1064
                    Brick it then jack it up.
                    • kamotors
                      • Nov 2007
                      • 7102
                      well I just looked around an banged around on stuff under the car and theirs nothing under their thats loose, all the exhaust is tight, catalytic converter heat shield is fine.
                      7speedshop.com
                      • T Verdier
                        • Aug 2007
                        • 2636
                        Is it a cheap cat or an OEM one because I had a cheap cat in my car and it made the same sound as a heat shield or loose exhaust. It was coming apart from the inside
                        • Streichholzschächtelchen
                          • Jan 2009
                          • 1670
                          Cats self destruct sometimes. Pulled one once and chunks of the filter material came out.
                          Jah bless! :pimp:
                          • kamotors
                            • Nov 2007
                            • 7102
                            its a catco high flow cat, last time I had the exhaust apart everything in their seemed solid.
                            hopefully not, I got to get my car smogged tomorrow:( but its a possibility.
                            7speedshop.com
                            • kamotors
                              • Nov 2007
                              • 7102
                              FIXED, it was the first exhaust hanger, the nut came off so the exhaust could rattle around up front.
                              7speedshop.com
