Turner Sways on a 89' 325ic
    Anyone using these Turner Motorsports Sways on their convertible?
    Im ready to pull the trigger and I just wanted to see if anyone was running them and if they liked them. Any problems or modifications for the install?
    How much of a difference to OEM? Night and day?
    Also I hear u need these and should weld them up on installation, so you dont rip out your mounts. Opinions please?
    Thanks!
    yes people like these. and yes you should weld them :)
    http://instagram.com/dslovn.drives
      I had these on my 'vert and they were great. absolutely fantastic. they were coupled with H&R cabrio springs, as well as Bilstein Sports with upgraded rear shock mounts.
      I would do it.
      sigpic89 M3
        Honestly I'd go for IE's kit, same diameter sways and comes with the rear bar chassis reinforcements included for $440, instead of $350 + $125.
        I'm not sure why you'd want to weld the rear chassis brackets or where you'd want to weld them, as then you wouldn't be able to remove the rear bar, or if you were to weld it to the trunk and not to the subframe, you'd have to remove the subframe to change out the rear bar.
        paint sucks
