Is www.rimpro.com dead for you?
  • UNHCLL
    • 8790
    www.rimpro.com does it work for you?
    Message time: 12:05AM Friday
    Below the radar...
  • Brew
    • 3060
    negatory
    '91 318is
    • M-technik-3
      • 18946
      nope works for me.
      • UNHCLL
        • 8790
        damn, back up again.
        was down when i posted. :roll:
        Below the radar...
        • DanGillan
          • Mar 2004
          • 4061
          chris, if you need anything done for VRS or yourself, make sure you let me know, we have a hook up at rimpro, dan used to run it, let me know
          Dan
          • M-technik-3
            • 18946
            Prices have gone up substantially. $160 a wheel.
            • DanGillan
              • Mar 2004
              • 4061
              no check again, straightneing up to a 17 inch rim is still only $100, for all you suckers that is
              Dan
              • UNHCLL
                • 8790
                Greg and I are looking into Refinishing. Straightening doesnt matter.
                I've got ~12 to be done... + gregs 4 (at minimum)..... we'll see.
                Below the radar...
                • M-technik-3
                  • 18946
                  Right from their site.
                  Straightening
                  The most cost effective solution!
                  The existing wheel finish is maintained
                  The wheel still matches age/finish of others on the car!
                  Most bent wheels are repairable
                  Prices for Straightening:
                  Wheels up to 17"---$100
                  Wheels up to 18-19"---$135
                  Wheels up to 20" and up---Call
                  Call for wholesale prices!
                  Our strength is in our straightening. “The straightest wheel in the industry,” RimPRO has a proprietary process that has allowed us to bring wheels beyond “usable” to the near perfect specification of +/- .010” Our machines are designed to remove the dent, ding, or bend without the use of heat that can compromise the temper or composition of the alloy. ! RimPRO is in business to solve wheel problems.
                  Typically, this involves 1 of 3 options:
                  Download a copy of our Work Order Here!
                  Have a look at some of the cars we have done work on here!
                  Straighten: The customer has a vibration problem
                  Refinish/restoration: Includes straightening, the customer has an ugly wheel that has been scratched, oxidized, or run down a curb. We can swap out for a refinished wheel from stock or do their own.
                  Replace: If the wheel is badly damaged or not repairable, it can simply be replaced with a used wheel or an outright purchase of a refinished wheel.
                  Refinishing
                  The wheel is first checked in and visually inspected for cracks and bends. It is then straightened if necessary using our proprietary straightening process to within +/- .010 inch. It is then cleaned and sandblasted. Now, any missing pieces are welded back in, and machined down. Next the wheel is primed using top quality etching primer for the best possible adhesion and corrosion resistance. Then OE matched color is applied in two coats, and two coats of clear are applied over the color. The wheel is then cooked under a shortwave light for ultimate hardness and abrasion resistance. The final product is in fact of higher quality than the OE finish, and carries a lifetime warranty against chipping, peeling, or discoloration.
                  Painted or machined Wheels up to 17"--- $160
                  Painted or machined Wheels 18-19"--- $195
                  Painted or machined Wheels 20" and up--- Call for details
                  Polished wheels--- Starting at $195--- Call for details
                  Two or three piece wheels"--- Starting $295--- Call for details
                  Like new finish at a fraction of the cost of a new wheel!
                  Removes unsightly oxidation, curb rash, and discoloration
                  Best color match in the industry!
                  Lifetime Warranty against corrosion and peeling!
                  • DanGillan
                    • Mar 2004
                    • 4061
                    i was looking at straightening
                    do you guys want to maybe tell me how many wheels you need done, and ill add mine to that, and ill see what I can do on a price, i know i can get a good hook up, so let me know timeframe and how many wheels
                    Dan
                    • UNHCLL
                      • 8790
                      depends on price.
                      I'd probably be in for 4... maybe 8. No need until spring, so any time over winter.
                      Below the radar...
                      • M-technik-3
                        • 18946
                        Originally posted by UNHCLL
                        depends on price.
                        Exactly as mine are coming off car next week. And the VW shows up maybe next week.
                        • DanGillan
                          • Mar 2004
                          • 4061
                          ok guys, im gonna talk to tom and ill find out, 4-8 for chris, 4? for greg, and 4 for me over the winter, ill get back to you guys about cost of refinishing/straightening asap
                          Dan
                          • M-technik-3
                            • 18946
                            I will have one set that need's straightning and one set refinishing.
                            • DanGillan
                              • Mar 2004
                              • 4061
                              ok
                              ill get a price estimate for you guys asap
                              Dan
