Removing injectors???
  • dager325
    • Nov 2007
    • 185
    This might sound stupid but how do you get the injectors off the intake manifold. I have them disconnected from the fuel rail but how do you get them off the intake. I have a m20b25 head and intake just preping it for a 2.7i. Thanks
  • Van Westervelt
    • 9365
    Pull straight out/up and twist. It takes some force, so man up.
    • TexasTerp
      • Jan 2009
      • 3541
      Originally posted by van westervelt
      pull straight out/up and twist. It takes some force, so man up.
      +1
      stephenbrody.com
      • slow e30
        • Jul 2009
        • 398
        just use the good ol fashioned muscles, mr muscly arms
        whatever you do, do not add any oil based liquid to it. it will ruin the seals.
        • nickpdx
          • 679
          when you get to re-installing the injectors, coat the o-rings with a light coat of motor oil
          • dager325
            • Nov 2007
            • 185
            Ok they came right out. I just didnt want to start pulling on them and break something. They are a lil rusted on the outside what should I do about cleaning them or painting them?
            • dager325
              • Nov 2007
              • 185
              Ok...So I do or don't oil the o-rings???
              • StereoInstaller1
                GAS
                • 22679
                Lube the Orings with a silicone based lube, NOT motor oil...and replace every damn one of them, including the orings on the FPR.
                If you want a cheap source for good orings, go to NAPA for Ford orings.
                '97 F150 should be a good call on "what kind of car is that, Sir?" bullshit.
                Closing SOON!
                Thanks for 10 years of fun!
                • SpecM
                  • Oct 2005
                  • 4531
                  yep, it'll cost $10 or $15 for all of them, if that
                  I use CRC Silicone Spray for lube
                  1989 cirrisblau-metallic 325i
                  • arch4ngel
                    • Dec 2008
                    • 791
                    How will using engine oil hurt the orings?
                    Project
                    Feedback
                    • Wh33lhop
                      • 11705
                      Eh, I used some 10W30 I had laying around. Helped a LOT with reinstallation. I'm planning on replacing the orings and cleaning the injectors anyway, so it's not a huge deal.
                      Didn't know it would degrade the seals though.
                      paint sucks
                      • arch4ngel
                        • Dec 2008
                        • 791
                        Yea, I just did mine last weekend and used some random royal purple gear oil I had lying around.
                        FYI according the the pelican article on cleaning injectors it's ok to use engine oil...
                        Project
                        Feedback
                        • Van Westervelt
                          • 9365
                          Thats what I have a small thing of Vaseline in my garage for. Petroleum jelly is your friend. Just be ready for the unknowing friend to make a wisecrack when they open your tool box, and you have some sittin on the side. ;)
                          • Wh33lhop
                            • 11705
                            ...Suuuuuuure. ;)
                            seewhatididthere?
                            paint sucks
                            • Cha Ching
                              • 1668
                              I use Astroglide for maximum shits & giggles...
