honest response
but here are the specs, it's my other car that I built
ENGINE:
Autotech 2035cc
10:1 Compression Ratio
Autotech Sporttuned GTI Big Valve Head
Euro "G" Grind Camshaft
Autotech Sporttuned Baffled Oil Pan
10 Row Thermostatic Oil Cooler Kit
Severe Duty Oil Pump
Oettinger Aluminum Valve Cover
INDUCTION:
Weber Dual 40mm Sidedraft Carbs
Match Ported & Polished Intake Manifold
Soft Mount Kit
K&N Air Filters
EXHAUST SYSTEM:
European GTI Exhaust Manifold
European GTI Exhaust Downpipe
HoR Technologies Muffler w/stainless steel Tip
BRAKES:
Autotech 10.1 Big Brake Kit
Autotech Rear Disc Brake Kit
Autotech Stainless Steel Brake Lines
Repco Metal Master Brake Pads
Directional Frt/Rr Cross-Drilled Rotors
BODY:
BBS Front Spoiler
Zender Fender Flares
Zender Side Skirts
Zender Rear Wing
Zender Front Grille
Frt/Rr European Bumpers
Fuba Amplified Antenna
LIGHTING:
Hella Quad 5 3/4" Round H-4 Headlamps
Hella Relays
European Side Blinkers
90 Amp Alternator
TRANSMISSION:
5 Speed GTI Limited Slip
.75 Fifth Gear Conversion
Sachs 210mm Sport Clutch
Autotech Short Shift Kit
Autotech Shiftweight
SUSPENSION:
Koni Front Adjustable Sport Struts
Koni Rear Adjustable Sport Shocks
Koni Progressive Rate Sport Springs
Autotech Heavy Duty Strut Bearings
Autotech Polyurethane Bushings Frt/Rr
Autotech Frt/Rr Hollow Sway Bars
Autotech Front Aluminum Stress Bar
Autotech Lower Stress Bar&Subframe
Autotech Rear Aluminum Stress Bar
16V Power Rack&Pinion Steering Unit
WHEELS & TIRES:
Etoile 16 inch 2 Piece Forged Polished Alloys
Yokohama AVS Intermediate Tires 205/45/ZR16
INTERIOR:
Recaro GLI Sport Seats
16V Rear Seat Bench
120 mph White Speed/Tach Gauge Faces
VDO Volt/Oil Temp/Oil Pressure Gauges
Momo Monte Carlo Steering Wheel
ENGINE:
Autotech 2035cc
INDUCTION:
Soft Mount Kit
K&N Air Filters
EXHAUST SYSTEM:
BRAKES:
BODY:
BBS Front Spoiler
Zender Side Skirts
Zender Rear Wing
Zender Front Grille
LIGHTING:
Hella Relays
90 Amp Alternator
TRANSMISSION:
SUSPENSION:
WHEELS & TIRES:
INTERIOR:
16V Rear Seat Bench
