Brake fluid question
  • formula driver
    • 2263
    Im doing SS lines in a few months. So my question is... will DOT-3 brake fluid work until then? Thanks
    P.S.. sorry if this seems like a stupid question
  • AndrewBird
    The Mad Scientist
    • 11898
    What do you mean will it work until then? You mean you need to fill up the resivour and are wonder if DOT 3 will be all right? It will be fine as long as you don't have DOT 5 fluid in there now. DOT 5 can not be mixed with other DOT numbers, but all other can be mixed together. DOT 3 is more then quality enough unless you are doing some serious braking all the time.
    • Brew
      • 3060
      Yeah, kind of a stupid question. But I would recommend you go with a DOT 4 brake fluid.
      '91 318is
      • formula driver
        • 2263
        lol.... I know I know. I can build a formula car from the frame up and its kinda sad but Ive just never had a good understanding of the differences in brake fluid.
        Nitro... I never had DOT 5. It was DOT 4 I believe but I flushed all the old fluid out. So its only DOT 3 now.
        Thanks alot fellas.... I can throw my Koni's on and Drop her off the jackstands now. 8)
