Do LSDs work in reverse?
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    Maybe a dumb question, but do they? I keep leaving a one-tire-fire in the driveway of a certain few R3v members every time I back out, and I'm wondering if it's my LSD that's shot or if they just don't work when turning the other way. Thanks guys.
  • Julien
    • 7472
    afaik they always work... methinks your clutch discs are worn out
    Build Threads:
    • Wh33lhop
      • 11705
      AFAIK BMW LSDs are one-way, meaning they work on acceleration only, not deceleration (or acceleration in reverse). Your LSD should act very little when you are coasting so you can get around corners well, it only tries to lock up when you apply forward torque.
      If you had a 2-way LSD it would work in reverse.
      I have noticed after a rain spinout (I was testing the LSD out :p) that when I got on it in reverse only one tire spun, wasn't surprising at all to me since I already thought they were 1-way.
      paint sucks
      • bimmerboy12
        • Jun 2004
        • 1057
        mine works in reverse... but then again it is a viscous coupling :)
        1988 325iC Project - FINISHED!
        Build Thread: http://www.r3vlimited.com/board/show...ht=325iC+paint
        • kamotors
          • Nov 2007
          • 7102
          once I got stuck in the snow and when I would reverse only one tire would spin at a time.
          7speedshop.com
          • CorvallisBMW
            • 13039
            hmmmm... 2 say yes and 2 say no. This is getting interesting.
            • Julien
              • 7472
              My understanding of the limited slip assembly in a BMW is the following:
              The system is always locked (@ 25%) via a set of clutch packs. When you take a turn one clutch pack or the other with start slipping allowing one wheel to turn faster than the other.
              Some reasons I can see it not working are:
              1. if you are backing up a steep driveway, there will be next to no weight on the wheels but a high demand for grip, if this situation passes the 25% tolerance of the clutch packs, one wheel will slip.
              2. Your clutch packs are generally worn out. Going forward you have the entire weight of the car pushing down on the rear wheels giving you more natural grip, hence why an open diff can leave 2 tire marks when peeling out.
              3. Jesus doesn't like you :-(
              anyways, clutch packs are cheap and seem fairly easy to install.
              Julien
              Build Threads:
              • CorvallisBMW
                • 13039
                Originally posted by Julien
                1. if you are backing up a steep driveway, there will be next to no weight on the wheels but a high demand for grip, if this situation passes the 25% tolerance one wheel will slip.
                This.
                It's a very steep driveway, with no room to get a 'running start' at it. Literally throw it in to reverse and start up a 20% hill for about 15 feet.
                Oddly enough though, it doesn't seem to happen in my 325iS or Kennys 318iS. Or even the e34 525iA, which I doubt has an lsd.
                the plot thickens...
                This one is also true.
                • Wh33lhop
                  • 11705
                  They don't. The idea is that they ramp up the locking force (ever heard of ramp rates?) as you ramp up the forward torque, and the force levels off at a certain locking coefficient (typically 25% for factory BMW diffs, however ours are worn out and exhibit closer to 10%). There is probably preload, but when you are coasting there is little locking force, and when you're applying reverse torque through the drivetrain there should be next to none.
                  paint sucks
                  • shiboujin
                    • Feb 2006
                    • 2791
                    Stock LSDs are 2 way
                    • Wh33lhop
                      • 11705
                      Originally posted by shiboujin
                      Well, that shut me up. Haha.
                      Open diffs can leave two tire marks, it really depends on how even the load is between the two tires. My guess is the LSD isn't working very well in reverse up a hill since there's very little load on your rear tires, effectively meaning there's very little ramp engagement. LSDs work on a load basis.
                      paint sucks
                      • shiboujin
                        • Feb 2006
                        • 2791
                        If you want proof, here's me at a drift day.
                        The first corner you hear my rpms drop, then I let the clutch out quickly. For a second the tires lock up in deceleration, then I power out. 2 way.
                        • slow e30
                          • Jul 2009
                          • 398
                          it is two way. hints how it has a percentage lockup on accel and decel
